Hello everyone!
I'm learning new things and for now I'm trying to add new GRUB entry for Nobara Linux in Garuda GRUB.
I tried various configs and so far I had no luck to make it actually work.
I'm seeing the new GRUB entry but when I choosing it I am keeping to receive the following error:
error: file '/boot/vmlinuz-6.3.9-200.fsync.fc38.x86_64' not found.
error: you need to load kernel first.
My current setup is:
- Garuda boot partition is on /dev/sda1
- Garuda root partition is on /dev/sda2
- Nobara boot partition is on /dev/sda3
- Nobara root partition is on /dev/sda4
Here is my current /etc/grub.d/40_custom config:
GNU nano 7.2 /etc/grub.d/40_custom
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
menuentry "Nobara Linux Boot" {
set root=(hd0,3)
linux /boot/vmlinuz-6.3.9-200.fsync.fc38.x86_64 root=UUID=baa9e24f-6422-44e5-b929-c0e9d2802c7c rw
initrd /boot/initramfs-6.3.9-200.fsync.fc38.x86_64.img
The UUID above is UUID for /dev/sda3 (where boot partition of Nobara is located).
I suppose I choose the right files from /dev/sda3, it contains this:
efi
grub2
loader
lost+found
.vmlinuz-6.3.9-200.fsync.fc38.x86_64.hmac
config-6.3.9-200.fsync.fc38.x86_64
elf-memtest86+-5.31
initramfs-0-rescue-b8b31546bc7f4702964e6c1de29e6aac.img
initramfs-freebsd.img
memtest86+-5.31
symvers-6.3.9-200.fsync.fc38.x86_64.gz -> /lib/modules/6.3.9-200.fsync.fc38.x86_64/symvers.gz
System.map-6.3.9-200.fsync.fc38.x86_64
vmlinuz-0-rescue-b8b31546bc7f4702964e6c1de29e6aac
So I can't figure out how to basically force the Garuda bootloader to use a kernel from another partition.
Also here is my garuda-inxi:
Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=d7813217-50b5-4ea5-bfb2-90984f4d37aa rw rootflags=subvol=@
ibt=off nobara
Type: Laptop System: Micro-Star product: GS65 Stealth Thin 8RF v: REV:1.0
Mobo: Micro-Star model: MS-16Q2 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16Q2IMS.112 date: 05/21/2019
ID-1: BAT1 charge: 80.3 Wh (100.0%) condition: 80.3/80.3 Wh (100.0%)
volts: 16.8 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: full
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF2
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 3098 high: 4101 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4100 2: 4038 3: 4016
4: 4001 5: 3390 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 4101 12: 2532
bogomips: 52799
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP104M [GeForce GTX 1070 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1ba1
Monitor-1: eDP-1 model: AU Optronics 0x80ed built: 2017 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0c76:161f class-ID: 0300
API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.72 status: active with: 1: pipewire-pulse
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 3d:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF: enp61s0 state: down mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6
Local Storage: total: 2.29 TiB used: 979.84 GiB (41.9%)
fw-rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: RBUSNS8180S3512GJ
tech: SSD serial: <filter> fw-rev: 61D1 scheme: GPT
ID-1: / raw-size: 383.02 GiB size: 383.02 GiB (100.00%)
used: 254 GiB (66.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 17.6 MiB (5.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 383.02 GiB size: 383.02 GiB (100.00%)
ID-4: /var/log raw-size: 383.02 GiB size: 383.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 383.02 GiB size: 383.02 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 12.5 MiB (0.1%)
System Temperatures: cpu: 48.0 C pch: 41.0 C mobo: N/A
Processes: 365 Uptime: 4m wakeups: 5 Memory: available: 15.47 GiB
used: 4.01 GiB (25.9%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: 1928 pm: pacman pkgs: 1910
libs: 554 tools: aura,octopi,paru pm: flatpak pkgs: 11 pm: snap pkgs: 7
Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.27
System install date: 2022-12-26
Last full system update: 2023-07-02
Any suggestions are highly appreciated. Thanks.
