Kernel: 6.1.0-0.deb11.11-amd64 arch: x86_64 bits: 64 compiler: gcc v: 10.2.1 clocksource: hpet
available: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.1.0-0.deb11.11-amd64
root=PARTUUID=e1ba93c9-a201-4f80-902a-94db727466de ro radeon.si_support=0 amdgpu.si_support=1
radeon.cik_support=0 amdgpu.cik_support=1 quiet
Console: pty pts/1 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 80TJ v: Lenovo ideapad 110-15ACL serial: <filter> Chassis:
type: 10 v: Lenovo ideapad 110-15ACL serial: <filter>
Mobo: LENOVO model: Nano 5A8 v: SDK0J40679 WIN serial: <filter> UEFI: Lenovo v: 1QCN32WW
date: 08/18/2016
ID-1: BATT charge: 0 Wh (0.0%) condition: 1.6/23.8 Wh (6.7%) volts: 7.3 min: 10.8
model: LENOVO LCFC type: Unknown serial: <filter> status: not charging
Info: model: AMD A8-7410 APU with AMD Radeon R5 Graphics socket: FT3b bits: 64 type: MCP
arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22) model-id: 0x30 (48)
stepping: 1 microcode: 0x7030105
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB
L2: 2 MiB desc: 1x2 MiB
Speed (MHz): avg: 1000 min/max: 1000/2200 boost: enabled base/boost: 2200/2200 scaling:
driver: acpi-cpufreq governor: conservative volts: 1.2 V ext-clock: 100 MHz cores: 1: 1000
2: 1000 3: 1000 4: 1000 bogomips: 17566
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Lenovo driver: amdgpu v: kernel
arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:9851 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon 520 Mobile]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 2 link-max: gen: 3 speed: 8 GT/s lanes: 8
bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380 temp: 43.0 C
Device-3: IMC Networks EasyCamera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 2-1.2:4 chip-ID: 13d3:a745 class-ID: 0e02 serial: <filter>
Display: server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 driver: gpu: amdgpu tty: 120x30
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15dc built: 2015 res: 1366x768 dpi: 101 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1
drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi
inactive: wayland,x11
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 23.2.1-arch1.2 note: console (EGL sourced)
renderer: AMD Radeon R5 Graphics (kabini LLVM 16.0.6 DRM 3.49 6.1.0-0.deb11.11-amd64), AMD
Radeon R5 M330 (hainan LLVM 16.0.6 DRM 3.49 6.1.0-0.deb11.11-amd64), llvmpipe (LLVM 16.0.6
256 bits)
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD Radeon R5 Graphics
(RADV KABINI) driver: mesa radv v: 23.2.1-arch1.2 device-ID: 1002:9851 surfaces: N/A device: 1
type: discrete-gpu name: AMD Radeon R5 M330 (RADV HAINAN) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:6660 surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: N/A
Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1022:780d class-ID: 0403
API: ALSA v: k6.1.0-0.deb11.11-amd64 status: kernel-api with: aoss type: oss-emulator
tools: N/A
Server-1: PipeWire v: 1.0.0 status: off with: 1: pipewire-pulse status: off 2: wireplumber
status: off 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo
driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8136
IF-ID-1: br-2843d63134e5 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-4: veth2525790 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: veth2d29dfc state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 2-1.1:3 chip-ID: 0cf3:e360 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: N/A rfk-block: hardware: no
software: yes address: N/A
Local Storage: total: 2.04 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: WDC WDS240G2G0A-00JH30 family: WD Blue /
Red / Green SSDs size: 223.58 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0000 temp: 42 C
SMART: yes state: enabled health: PASSED on: 1y 222d 8h cycles: 6387
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: BUP Slim WH size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: N/A serial: <filter> fw-rev: 0304
SMART Message: A mandatory SMART command failed. Various possible causes.
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: BUP Slim RD size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A
serial: <filter> fw-rev: 0302
Kernel: swappiness: 1 (default 60) cache-pressure: 50 (default 100) zswap: no
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
System Temperatures: cpu: 55.8 C mobo: N/A
GPU: device: amdgpu temp: 48.0 C device: amdgpu temp: 44.0 C
Processes: 283 Uptime: 2h 51m wakeups: 0 Memory: total: 8 GiB note: est. available: 6.68 GiB
used: 2 GiB (29.9%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 alt: 12 Packages: pm: pacman pkgs: 1516 libs: 434 tools: octopi,pamac,paru
Shell: Bash (sudo) v: 5.2.21 running-in: pty pts/1 inxi: 3.3.31
Garuda (2.6.19-2):
head: cannot open '/var/log/pacman.log' for reading: No such file or directory
System install date:
Last full system update: 2023-12-13
Relevant software: snapper NetworkManager connman dracut
Windows dual boot: Yes
I installed garuda with decryption and would like to remove it from /boot, to do that i need to move all kernels and initramfs to my actually partiton /dev/sda1 but i have never used dracut and since grub wont be handling decryption anymore i need to add cryptsetup to my initramfs and also ssh to decrypt over ssh if possible.How would i do this with dracut?
