Good night.
I would like to know if Garuda comes with ADB and Fastboot installed/enabled, if not, how can i install on it?
Has anyone ever used Garuda to install a custom rom on a Android phone? Cheers.
Good night.
nstall like all other app's
sudo pacman -S android-tools
Yes, if TWRP is installed
Thank you for the help.
It was installed and updated, but i did reinstall it just to make sure.
It's the first time im trying it, bought a new phone to try, is the only way to really learn... i just hope i do not screw up! ...TWRP is about security updates right?
Heres what i found looking for it, on the phone model i got:
https://twrp.me/motorola/motorolamotog7plus.html
If the phone is unlocked you can probably just fastboot flash and be done with it.
What brand and model phone do you have?
fastboot
Using fastboot
(if your device supports it) should simply involve rebooting to fastboot mode. While in fastboot mode, you can type fastboot devices
to verify that your device is being detected
Is this the way to know if the phone i bought supports it?
It's a Motorola G7 Plus, just bought, brand new one. If possible, i would like to install the custom rom without having to login with a Google Account on it, not sure itś possible tough, from what i read, i need to activate develop mode.
https://forum.xda-developers.com/c/moto-g7-plus.8544/
Everything you would ever like to know.
Thank you very much, i will have a deeper reading into it, any doubts, i comment here again! I truly appreciate it!
