Since the update to Plasma 6 the actions menu, the menu that pops up when right clicking on the title bar of a window always opens where the global menu on the default dragonized theme is. I like the dragonized colors but don’t like the global menu.
I have been search the internet, the forums, the system settings, and can’t find anyway to change this behavior. Is this just the way plasma behaves now? Or is there a setting somewhere that I am missing?
As you can see with my setup right clicking on the right monitor then having to go all the way to the left side of the left monitor is super annoying.
Any advice to get my setup working how it was with plasma 5 would be much appreciated.
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=89bff1a7-521e-4982-a6ca-a17250fb7b4e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
UEFI: American Megatrends v: 2803 date: 04/27/2022
Device-1: ps-controller-battery-58:10:31:7a:70:a0 model: N/A serial: N/A
charge: N/A status: charging
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4049 high: 4315 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3757
3: 3600 4: 4315 5: 4299 6: 4299 7: 4299 8: 4300 9: 4300 10: 3600 11: 3600
12: 3600 13: 4299 14: 4313 15: 4303 16: 4303 bogomips: 115207
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 0a:00.0
chip-ID: 1002:7340 class-ID: 0300
gpu: amdgpu d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-3 pos: primary,top-left res: 3440x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd v: N/A glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 5500 XT (radeonsi navi14 LLVM
17.0.6 DRM 3.57 6.8.1-zen1-1-zen) device-ID: 1002:7340 memory: 7.81 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 5500 XT (RADV NAVI14) driver: mesa radv
v: 24.1.0-devel (git-2743adac7f) device-ID: 1002:7340
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.0-devel (git-2743adac7f)
(LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab38
Device-3: Sony DualSense wireless controller (PS5)
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 054c:0ce6 class-ID: 0300
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
Device-2: Sony DualSense wireless controller (PS5)
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
Local Storage: total: 4.32 TiB used: 1.78 TiB (41.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FPK002T
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SN10932 temp: 41.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Smart Modular Tech.
model: SHGP31-500GM-2 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 41061C20 temp: 37.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:2 vendor: Crucial model: CT1000P1SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR021 temp: 40.9 C
ID-4: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240M500SSD1
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: MU03 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Mushkin model: MKNSSDS2960GB
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 8A0 scheme: GPT
ID-1: / raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
used: 86.61 GiB (20.1%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:6
used: 29.7 MiB (9.9%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 418.4 GiB (44.9%) fs: btrfs dev: /dev/nvme2n1p1 maj-min: 259:3
ID-4: /var/log raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.95 GiB used: 667.5 MiB (1.4%)
ID-2: swap-2 type: partition size: 34.43 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:7
System Temperatures: cpu: 52.5 C mobo: N/A gpu: amdgpu temp: 39.0 C
mem: 0.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1356
Memory: total: 48 GiB available: 46.95 GiB used: 5.72 GiB (12.2%)
Processes: 456 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.74 GiB services: org_kde_powerdevil,upowerd
Packages: 2767 pm: pacman pkgs: 2747 libs: 614 tools: octopi,paru
pm: flatpak pkgs: 20 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: Bash v: 5.2.26 running-in: yakuake inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2022-07-10
Last full system update: 2024-03-22
╭─sam@samticus in ~ took 2s
╰─λ
╰─λ garuda-inxi
Speed (MHz): avg: 4195 high: 4350 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4342 2: 4350
3: 3600 4: 4273 5: 4299 6: 3708 7: 4327 8: 4342 9: 3600 10: 4317 11: 4320
12: 4348 13: 4326 14: 4299 15: 4329 16: 4341 bogomips: 115207
lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR021 temp: 41.9 C
ID-1: swap-1 type: zram size: 46.95 GiB used: 660.2 MiB (1.4%)
System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
mem: 0.0 C
Memory: total: 48 GiB available: 46.95 GiB used: 5.7 GiB (12.1%)
Processes: 458 Power: uptime: 2m states: freeze,mem,disk suspend: deep
Garuda (2.6.23-1):
