Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ed32595a-d211-4658-b067-e481188b5b26 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.1 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX II (MS-7C02) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.90
date: 07/25/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3691 high: 3700 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 3600 8: 3700 9: 3700 10: 3700 11: 3700
12: 3700 bogomips: 88800
Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: PNY driver: nvidia
v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 26:00.0 chip-ID: 10de:2487
compositor: kwin_x11 driver: X: loaded: nvidia unloaded: modesetting,vesa
alternate: fbdev,nouveau,nv gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 6960x1920 s-dpi: 109 s-size: 1622x447mm (63.86x17.60")
s-diag: 1682mm (66.24")
Monitor-1: DP-0 pos: bottom-r res: 1920x1080 hz: 60 dpi: 92
Monitor-2: DP-2 pos: primary,top-left res: 1200x1920 hz: 60 dpi: 94
size: 324x518mm (12.76x20.39") diag: 611mm (24.05") modes: N/A
Monitor-3: DP-4 pos: top-center res: 3840x1600 hz: 60 dpi: 111
size: 879x366mm (34.61x14.41") diag: 952mm (37.49") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX
3060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel bus-ID: 5-1.1:4 pcie: chip-ID: 0499:170f
gen: 3 class-ID: 0103 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 26:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Yamaha Steinberg UR22mkII type: USB driver: snd-usb-audio
Device-4: Intel USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:3 chip-ID: 8086:0808
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
bus-ID: 3-1.4:3 chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Local Storage: total: 4.12 TiB used: 1.49 TiB (36.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1014 size: 476.94 GiB block-size: physical: 512 B
rev: 20110000 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD120 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB model: USB DISK 2.0 size: 14.44 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: PMAP scheme: MBR
used: 95.63 GiB (20.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 31.0 C mobo: 30.0 C gpu: nvidia temp: 50 C
Fan Speeds (RPM): fan-1: 2343 fan-2: 685 fan-3: 718 fan-4: 0 fan-5: 0
fan-6: 0 gpu: nvidia fan: 0%
Processes: 367 Uptime: 5m wakeups: 0 Memory: 31.27 GiB
used: 4.71 GiB (15.1%) Init: systemd v: 253 default: graphical
pkgs: 1889 libs: 459 tools: gnome-software,octopi,pamac,paru,yay Shell: fish
v: 3.6.0 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-02-21
Last full system update: 2023-02-25
Hello. I somehow manage to change the /usr/bin ownership and now I'm trying to give it back to root. I receive these errors :
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
or
chown: changing ownership of '/usr/bin/sudo': Operation not permitted
I managed to go to recovery mode and chown root:root /usr/bin/sudo and `chmod 4755 /usr/bin/sudo , but when I type ls -l /usr/bin/sudo I receive
.rwxr-xr-x 249k root 15 фев 23:35 /usr/bin/sudo
Any ideas how to procede from here? I think the outcome should be something like -rwxr-xr-x 1 root root
