Hello Garuda community... Im not "New" or "Newbie" in the linux world but when i started looking for the "perfect" system i choose Garuda as my base for this "perfect" system.
So i came across something that actually confuse me a little bit it looks "simple" but as what i mention before im looking for the "perfect" system as possible on low-end "AMD" laptop...
What im asking here is not an real "Issue" but an "Assistance" by providing your opinion and feedback about the "Powersave Tweaks" with the packages and services "Garuda Assistant" provides...
For example and really what makes me open this "conversation" is those packages:
- Power-profiles-daemon
- Auto-cpufreq
- Thermald
- Or maybe something else ??!
Intel-undervolt not included because im using AMD Cpu.
I read about these packages but really i want a real feedback from someone using them or someone just know how they work with real PRACTICAL use to get the "best?" performance without destroying the battery life.
And last thing... before someone send "Arch Wiki" link please consider give some opinion or kind of recommended option for my hardware.
Kernel: 6.2.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ade973e4-0704-4da1-b261-3d2889e3b6ce rw [email protected]
quiet systemd.show_status=auto rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=6cc7eeee-95bc-4b8a-8052-6f918c00c926 loglevel=3
mitigations=off pcie_aspm=force ibt=off
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: HP product: HP 255 G6 Notebook PC
Mobo: HP model: 8330 v: 27.35 serial: <superuser required> UEFI: Insyde
v: F.53 date: 06/19/2020
ID-1: BAT1 charge: 22.0 Wh (76.7%) condition: 28.7/31.1 Wh (92.5%)
volts: 12.4 min: 10.9 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: AMD A6-9225 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64 type: MCP
arch: Excavator level: v3 note: check built: 2015 process: GF 28nm
family: 0x15 (21) model-id: 0x70 (112) stepping: 0 microcode: 0x6006705
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1296 high: 1297 min/max: 1300/2600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1295 2: 1297
bogomips: 10381
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 ports: active: DP-1,eDP-1
empty: HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 2646x1024 s-dpi: 96 s-size: 700x271mm (27.56x10.67")
s-diag: 751mm (29.55")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
model: AG Neovo F-419 serial: <filter> built: 2006 res: 1280x1024 dpi: 86
gamma: 1.2 size: 376x301mm (14.8x11.85") diag: 476mm (18.8") ratio: 5:4
modes: max: 1280x1024 min: 640x350
Monitor-2: eDP-1 mapped: eDP pos: left model: BOE Display 0x06a5
built: 2015 res: 1366x768 hz: 60 dpi: 101 gamma: 1.2
max: 1366x768 min: 640x480
missing.
Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 1-1.1:4 chip-ID: 0d8c:0012 bus-ID: 00:01.1 chip-ID: 1002:15b3
class-ID: 0300 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
Device-3: C-Media USB Audio Device type: USB
Sound API: ALSA v: k6.2.8-zen1-1-zen running: yes
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
Local Storage: total: 447.13 GiB used: 90.8 GiB (20.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 447.13 GiB
serial: <filter> rev: 7A0 scheme: GPT
ID-1: / raw-size: 308.53 GiB size: 308.53 GiB (100.00%)
used: 6.05 GiB (2.0%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 308.53 GiB size: 308.53 GiB (100.00%)
ID-4: /var/log raw-size: 308.53 GiB size: 308.53 GiB (100.00%)
ID-5: /var/tmp raw-size: 308.53 GiB size: 308.53 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.16 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 1 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 60.1 C mobo: N/A gpu: amdgpu temp: 60.0 C
Processes: 214 Uptime: 4h 3m wakeups: 3 Memory: 11.16 GiB
used: 2.62 GiB (23.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: 1116 pm: pacman pkgs: 1110
libs: 334 tools: pamac,paru pm: flatpak pkgs: 6 Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.25
System install date: 2023-03-24
Last full system update: 2023-03-24
