Hello guys ,
so I was recently getting very annoyed with my new browser floorp ,
because it is very fast but I use to give online tests on some websites which when I open on floorp , it just consumes humongous amount of memory ,
I found that there is an option to reduce it , you can just find it by searching performance
, you can select the option which is for minimal memory usage :
well, after that you feel like it had got a little slower (obviously the less ram consumption means slower things )
but you can make it fast again , just look the screenshot I uploaded above , you can another option written as user.js
, go into it and apply the option named as Yokoffing fastfox
, at the spot you apply your browser will restart
and then you will get some thing which would might just impress you
Well, I didn’t needed to certainly make any post or new topic but for those fellas who want to use floorp but the site they mostly use are just, soo big that their 8GB ram stick laptops can’t handle it well, then it would might help(Really it was consuming 7GB of the ram ) , because I believe there are many students like me in this community who can’t afford very powerful beasts at their current state
well IDK if I would apply other options from user.js
then whether it will override previously applied option so I don’t wanna play with it , I just got what I needed
Well, even there no use of garuda-inxi still here you go :
Summary
â•─ankur@ankur in ~
╰─λ garuda-inxi
Kernel: 6.7.0-4-cachyos arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4db91e48-f647-49c5-9e3e-ea266109ffe7 rw rootflags=subvol=@
Type: Laptop System: Dell product: Inspiron 7570 v: N/A
Mobo: Dell model: 06K08K v: A00 serial: <superuser required> UEFI: Dell
v: 1.25.0 date: 07/13/2022
ID-1: BAT0 charge: 6.6 Wh (100.0%) condition: 6.6/42.0 Wh (15.7%)
volts: 12.6 min: 11.4 model: Samsung SDI DELL CYMGM79 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 400 min/max: 400/4000 scaling: driver: intel_pstate
governor: performance cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400
7: 400 8: 400 bogomips: 31999
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134d
class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3
chip-ID: 1bcf:28c1 class-ID: 0e02
compositor: Hyprland driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: BOE Display 0x06b4 built: 2016 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 scale: 1 size: 344x194mm (13.54x7.64")
API: Vulkan v: 1.3.274 layers: 11 device: 0 type: integrated-gpu
name: Intel UHD Graphics 620 (KBL GT2) driver: mesa intel v: 23.3.3-arch1.2
device-ID: 8086:5917 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce 940MX driver: nvidia v: 545.29.06
device-ID: 10de:134d surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 23.3.3-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
API: ALSA v: k6.7.0-4-cachyos status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2a
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 66.3 GiB (5.7%)
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: L003 scheme: GPT
used: 66.3 GiB (7.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.5 GiB used: 132.2 MiB (1.7%) priority: 100
System Temperatures: cpu: 49.0 C pch: 47.5 C mobo: N/A
Processes: 258 Uptime: 57m wakeups: 0 Memory: total: 8 GiB
available: 7.5 GiB used: 3.22 GiB (42.9%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1636 libs: 464 tools: pamac,paru pm: flatpak
pkgs: 0 Shell: fish v: 3.7.0 running-in: foot inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-10-15
Last full system update: 2024-01-12
â•─ankur@ankur in ~ took 15s
╰─λ
