Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e70d0b43-49a5-4fee-ab01-12700cf5d7ea rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: PRO Z690-A DDR4(MS-7D25) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.10
date: 12/13/2021
Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
microcode: 0x2E
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 3518 high: 3700 min/max: 800/4900:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 3700 2: 3700 3: 3700
4: 3700 5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 800 12: 3700
13: 3700 14: 3700 15: 3700 16: 3700 bogomips: 117964
Device-1: Intel AlderLake-S GT1 vendor: Micro-Star MSI driver: i915
v: kernel ports: active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2,
HDMI-A-3, HDMI-A-4 bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0380
Device-2: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: PNY driver: nvidia
v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia display-ID: :0
s-diag: 610mm (24")
Monitor-1: DP-2 res: 1920x1080 hz: 165 dpi: 92
size: 530x300mm (20.87x11.81") diag: 609mm (23.98") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX 1060
3GB/PCIe/SSE2 direct-render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: PNY
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
Device-2: MediaTek MT7612U 802.11a/b/g/n/ac Wireless Adapter
driver: mt76x2u type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
bus-ID: 2-6:3 chip-ID: 0e8d:7612 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u6 state: up mac: <filter>
Local Storage: total: 3.86 TiB used: 28.07 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
tech: SSD serial: <filter> fw-rev: B1E1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001
used: 28.07 GiB (12.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.0 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 29%
Processes: 347 Uptime: 3m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.42 GiB used: 3.06 GiB (19.8%) Init: systemd v: 254
pm: pacman pkgs: 1328 libs: 425 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date: 2023-09-08
Last full system update: 2023-09-08
I have installed Garuda for the first time and run into a severe issue. It started happening at first when creating a partition on my drive, when I opened up FireDragon and when some popups occur, is the app becomes see through, and every time I click it. It opens a Window Manager. Even after clicking on Window Manager popup, it opened up another one from it.
This clears up after I restart my pc but it happens every other restart or boot from what I've noticed.
