Hey I own a AMD 7900XTX and while I may be new to Garuda, I’ve used other Arch distros in the past.
But I always keep running into this major problem : Getting fan curves on my 7900XTX.
CoreCtrl Doesn’t work.
LACT Doesn’t work.
Trying to edit /sys/class/drm/card1/device/gpu_od/fan_ctrl/fan_curve doesn’t work ( or I did it wrong/permission issue ).
6.7 kernel was suppose to include a way for us to control RNDA 3 fan speeds right?
I’m on 6.7.5-zen1-1-zen.
I’m at my rope’s end on this and am utterly desperate. If this is something not possible with Arch at all, I really would like advice on another distro that would 100% work with this card.
SGS
21 February 2024 20:15
2
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
ONE issue per topic.
Describe your issue in detail. The more we know, the better we can help
Show us the results of your searches, and what you’ve tried
After rebooting, post the FULL output of garuda-inxi
in the body of the post (not linked externally, or collapsed with the “hide details” feature)
Format terminal output (including your garuda-inxi
) as a code block by clicking the preformatted text button (</> ) , or put three tildes (~) above and below the text
Without garuda-inxi this request will be moved to 412 Precondition Failed
Seems new hardware in use, just wait a little or try M$.
Ah sorry, here’s the inxi
Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=05ff0ead-9d40-4317-a80c-782a377691ea rw rootflags=subvol=@
v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop System: Gigabyte product: X570 AORUS ELITE WIFI v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE WIFI serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F38b
date: 03/23/2023
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2396 high: 2873 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2799 2: 2777
3: 2770 4: 2268 5: 2263 6: 2261 7: 2205 8: 2429 9: 2250 10: 2235 11: 2200
12: 2200 13: 2200 14: 2228 15: 2650 16: 2239 17: 2200 18: 2453 19: 2200
20: 2602 21: 2873 22: 2818 23: 2200 24: 2207 bogomips: 177600
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire NITRO+ driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,DP-2 empty: HDMI-A-1,HDMI-A-2 bus-ID: 0b:00.0
chip-ID: 1002:744c class-ID: 0300
gpu: amdgpu d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-1 pos: right res: 2560x1440 size: N/A modes: N/A
Monitor-2: DP-2 pos: primary,left res: 2560x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.1-arch1.1
navi31 LLVM 16.0.6 DRM 3.57 6.7.5-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.0.1-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab30
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Audio-Technica ATR2100x-USB Microphone
lanes: 1 mode: 2.0 bus-ID: 3-6.1:5 chip-ID: 0909:004d class-ID: 0300
API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:3 chip-ID: 8087:0aa7
Local Storage: total: 15.01 TiB used: 2.73 TiB (18.2%)
model: WD BLACK SN750 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 112000WD temp: 48.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
model: WD60PURX-64WY0Y1 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5700 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 2TB
ID-6: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD40EZAZ-00SF3B0 size: 3.64 TiB block-size: physical: 4096 B
ID-7: /dev/sdf maj-min: 8:80 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
used: 47.78 GiB (10.3%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 588 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: zram size: 31.26 GiB used: 1.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 49.9 C mobo: 30.0 C gpu: amdgpu temp: 59.0 C
mem: 64.0 C
Memory: total: 32 GiB available: 31.26 GiB used: 11.19 GiB (35.8%)
Processes: 481 Power: uptime: 1h 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: 1766 pm: pacman pkgs: 1758 libs: 538 tools: octopi,paru,yay
pm: flatpak pkgs: 8 Compilers: gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-01-27
Last full system update: 2024-02-21
mad
21 February 2024 22:45
4
I have also an AMD 7900 XTX (Sapphire Nitro+), but I am sorry to say, with my limited knowledge, I was not able to get the fan control working, as a test for you (I do not need it controlled, it just works for me).
I have tried:
CoreCtrl
LACT
TuxClocker
None of them are reading the fan speeds. Even garuda-inxi is showing “fan: 0” on Sensors. Reading temperatures or wattage is usually fine, though. If anyone else has any ideas, I might help testing.
root=UUID=e69eb184-4f60-4c60-a81f-aa5e53e9580b rw rootflags=subvol=@
Mobo: ASUSTeK model: ROG STRIX B650E-F GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 2214 date: 01/02/2024
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 2597 high: 4394 min/max: 400/5050 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3545 2: 3993 3: 4306
4: 400 5: 400 6: 3764 7: 400 8: 3751 9: 4394 10: 4385 11: 400 12: 400
13: 3586 14: 3909 15: 400 16: 3528 bogomips: 134393
ports: active: DP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 03:00.0
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-3,HDMI-A-3
bus-ID: 0e:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 39.0 C
gpu: amdgpu,amdgpu display-ID: 0
Monitor-1: DP-1 res: 2560x1440 size: N/A modes: N/A
API: Vulkan v: 1.3.276 layers: 10 device: 0 type: discrete-gpu name: AMD
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 24.0.1-arch1.1 device-ID: 1002:164e
16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM 16.0.6)
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0e:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:15f3
Local Storage: total: 2.73 TiB used: 308.63 GiB (11.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 39.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 37.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 129.14 GiB (6.9%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
used: 129.14 GiB (6.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-1: swap-1 type: zram size: 62.02 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.1 C mobo: N/A
GPU: device: amdgpu temp: 39.0 C device: amdgpu temp: 52.0 C mem: 58.0 C
fan: 93 watts: 25.00
Memory: total: 64 GiB available: 62.02 GiB used: 5.11 GiB (8.2%)
Processes: 383 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.8 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1457 libs: 456 tools: octopi,paru Compilers:
clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0
Garuda (2.6.23-1):
System install date: 2024-01-25
Have you tried just downloading fancontrol-gui and setting to the amdgpu sensor of choice there for fan control. In my inxi it shows fan 0 and speed N/A but it is working and controls to the curve i set, i use it through fancontrol-kcm so its there in my system settings. i can easily verify its working by setting to 100 percent at lowest temp and hearing the fans lift off.
That ones a negative too.
Tried fancontrol-gui-git. Made a new profile, set the fan curve values all to 100%, started and enabled the services : no effect, no fan movement.
I know the fans of my GPU works during under load and in windows but in linux it has zero rpm enabled by default.
I recently got sick of the issue where HWMON devices can move around from boot to boot in the /sys filesystem, changing their absolute path, so I tried fan2go and found it very helpful because it talks directly to the HWMON nodes.
Not the same issue you’re having exactly, but you might find that it succeeds in your case where others failed. If it shows up in a fan2go detect
then you’ll be able to control it.
It should also be noted that fancontrol-gui doesn’t handle multiple devices well and churns out broken configurations right now if you have multiple HWMON platforms in the one machine:
https://github.com/Maldela/fancontrol-gui/issues/78
Beyond that, fan2go is awesome in general because you can do very complex control schemes.
I hope you have some luck!
system
Closed
7 March 2024 06:42
8
