Hello all! Just installed Garuda after buying an AMD RX 7900 XT and I've ran into my first issue.
When trying to use two monitors, certain UI elements of the desktop flicker, the cursor flickers, and the system feels generally laggy. When I'm using just a single monitor, everything works great! I've attached a video showcasing these issues:
One Monitor
Two Monitors
I was previously running a Garuda installation with the git amd drivers following this guide, but borked the OS somehow later and had to reinstall. This issue was also present with the git version.
I'm very new to Garuda and Arch, so please let me know what other information I can provide that would be helpful. I greatly appreciate any help in advance!
Here's my inxi:
╰─λ garuda-inxi
Kernel: 6.1.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a6b6a44d-748b-42d2-987f-49e7a270aec8 rw [email protected]
loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: PRIME X299-DELUXE v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 3701
date: 05/23/2022
Info: model: Intel Core i7-7820X bits: 64 type: MT MCP arch: Skylake
gen: core 7 level: v4 note: check process: Intel 14nm family: 6
model-id: 0x55 (85) stepping: 4 microcode: 0x2006E05
L3: 11 MiB desc: 1x11 MiB
Speed (MHz): avg: 3886 high: 4000 min/max: 1200/4300:4500 scaling:
driver: intel_pstate governor: performance cores: 1: 3744 2: 3749 3: 4000
4: 4000 5: 4000 6: 3820 7: 3977 8: 4000 9: 3967 10: 3942 11: 3766 12: 3761
13: 3766 14: 3781 15: 3911 16: 4000 bogomips: 115200
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1
bus-ID: c3:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 7-2.1:3 chip-ID: 046d:082d
compositor: kwin_x11 driver: X: loaded: amdgpu gpu: amdgpu display-ID: :0
s-diag: 777mm (30.58")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Dell S2721DGF
serial: <filter> built: 2022 res: 2560x1440 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
API: OpenGL v: 4.5 Mesa 22.3.2 renderer: llvmpipe (LLVM 14.0.6 256 bits)
direct render: Yes
driver: snd_hda_intel bus-ID: 1-6.3:4 v: kernel bus-ID: 00:1f.3
chip-ID: 1b1c:0a64 chip-ID: 8086:a2f0 class-ID: 0300 serial: <filter>
Device-2: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: c3:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-3: Corsair VIRTUOSO XT Wireless Gaming Receiver type: USB
Device-4: Logitech HD Pro Webcam C920 type: USB
Sound API: ALSA v: k6.1.4-zen2-1-zen running: yes
Device-2: Wilocity Wil6200 802.11ad Wireless Network Adapter
driver: wil6210 v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 43:00.0 chip-ID: 1ae9:0310 class-ID: 0280
IF: wlp67s0 state: down mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 46:00.0
IF: enp70s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-4: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 47:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 48.0 C
IF: wlp71s0 state: down mac: <filter>
Device-1: ASUSTek type: USB driver: btusb v: 0.8 bus-ID: 1-13:7
chip-ID: 0b05:1868 class-ID: e001
Local Storage: total: 7.3 TiB used: 672.02 GiB (9.0%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 32.9 C scheme: GPT
model: WDS200T1X0E-00AFY0 size: 1.82 TiB block-size: physical: 512 B
rev: 613000WD temp: 53.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 256GB
type: SSD serial: <filter> rev: 1B6Q
model: WD4004FZWX-00GBGB0 size: 3.64 TiB block-size: physical: 4096 B
rev: 0A81 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 PRO Series
type: SSD serial: <filter> rev: 6B0Q
ID-6: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 18.8 GiB (1.0%)
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
used: 18.8 GiB (1.0%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.03 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
mem: 60.0 C
Processes: 404 Uptime: 31m wakeups: 0 Memory: 31.03 GiB
used: 4.96 GiB (16.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1986
libs: 558 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2023-01-09
Last full system update: 2023-01-10
I believe the only major change I've made on the system is creating the file /etc/X11/xorg.conf.d/20-amdgpu.conf. I did this to fix an issue where the cursor would not display. Here are the contents of that file:
Section "Device"
Identifier "AMD"
Driver "amdgpu"
Option "SWCursor" "True"
Endsection
