Hey, so im trying to set my external display to 75hz to ease my eyes just a bit more, but i cant.
i realize that its because one of my monitors (laptop integrated) is 60hz and the external is 75hz, and xserver/opengl (one or the other, im not sure) can only sync to one of them, and coincidentally its syncing to the 60hz one.
Ive tried changing the synced display in nvidia-settings
but its stuck on "Auto" with no other options.
Ive also tried environmental variables like __GL_SYNC_DISPLAY_DEVICE="HDMI-1-2"
, messing around with the optimus-manager
config for xserver, disabling the compositor, and even disabling my integrated monitor, but nothing works.
I know for a fact that it should be able to do 75hz on 1920x1080 as it could on windows, even though xrandr-prop
is saying otherwise.
Thanks in advance!
Here is my xrandr -prop
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
eDP-1-1 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 344mm x 194mm
EDID:
00ffffffffffff0030e4330500000000
001a010495221378eaa1c59459578f27
20505400000001010101010101010101
0101010101012e3680a070381f403020
350058c21000001a0000000000000000
00000000000000000000000000fe004c
4720446973706c61790a2020000000fe
004c503135365746362d53504b3300bf
PRIME Synchronization: 1
supported: 0, 1
scaling mode: Full aspect
supported: Full, Center, Full aspect
Colorspace: Default
supported: Default, RGB_Wide_Gamut_Fixed_Point, RGB_Wide_Gamut_Floating_Point, opRGB, DCI-P3_RGB_D65, BT2020_RGB, BT601_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, BT2020_CYCC, BT2020_YCC
max bpc: 12
range: (6, 12)
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
panel orientation: Normal
supported: Normal, Upside Down, Left Side Up, Right Side Up
link-status: Good
supported: Good, Bad
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
CONNECTOR_ID: 95
supported: 95
non-desktop: 0
range: (0, 1)
1920x1080 60.02 + 60.01 59.97 59.96 59.93*
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1-1 disconnected (normal left inverted right x axis y axis)
supported: 0, 1
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
supported: force-dvi, off, auto, on
subconnector: Unknown
supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
link-status: Good
0 1
CONNECTOR_ID: 103
supported: 103
non-desktop: 0
range: (0, 1)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
supported: 0, 1
max bpc: 12
range: (8, 12)
content type: No Data
supported: No Data, Graphics, Photo, Cinema, Game
Colorspace: Default
supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
audio: auto
link-status: Good
0 1
CONNECTOR_ID: 113
supported: 113
non-desktop: 0
range: (0, 1)
HDMI-1-2 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 528mm x 297mm
EDID:
00ffffffffffff004c2d7d7058473630
131f010380351e782adfd5a35b4da125
0d5054bfef8081c0810081809500a9c0
b300714f0101023a801871382d40582c
450010292100001e000000fd00304b1e
5412000a202020202020000000fc004c
4632345433350a2020202020000000ff
00484b32523530303632300a2020013d
02031cb146901f0413031267030c0010
000024681a00000101304b00011d00bc
52d01e20b828554010292100001e8c0a
d090204031200c405500102921000018
8c0ad08a20e02d10103e960010292100
0018011d007251d01e206e2855001029
2100001e2a4480a07038274030203500
10292100001a00000000000000000018
supported: 0, 1
max bpc: 12
range: (8, 12)
Colorspace: Default
audio: auto
link-status: Good
0 1
CONNECTOR_ID: 119
supported: 119
non-desktop: 0
range: (0, 1)
1920x1080 60.00 + 50.00 59.94*
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1440x900 59.90
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
Here is my garuda-inxi
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=3bf66fc0-89ba-4f98-b6f6-81b2ff1ff168 rw rootflags=subvol=@
resume=UUID=fd7e8027-710d-411d-82b6-505a4c2b5304 loglevel=3
nvidia-drm.modeset=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Laptop System: Micro-Star product: GL62M 7REX v: REV:1.0
Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16J9IMS.31A date: 07/11/2017
ID-1: BAT1 charge: 36.1 Wh (95.3%) condition: 37.9/42.4 Wh (89.4%)
volts: 12.1 min: 10.8 model: MSI BIF0_9 type: Li-ion serial: N/A
status: N/A
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
desc: 1x6 MiB
Speed (MHz): avg: 3191 high: 3236 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 3236 2: 3084 3: 3220
4: 3224 bogomips: 19999
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915
v: kernel ports: active: HDMI-A-2,eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 510.68.02
alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0302
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-2 mapped: HDMI-1-2 pos: primary,left
model: Samsung LF24T35 serial: <filter> built: 2021 res: 1920x1080 dpi: 92
gamma: 1.2 size: 528x297mm (20.79x11.69") diag: 606mm (23.9") ratio: 16:9
Monitor-2: eDP-1 mapped: eDP-1-1 pos: right model: LG Display 0x0533
built: 2016 res: 1920x1080 dpi: 142 gamma: 1.2
modes: 1920x1080
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.68.02 direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:10a1 class-ID: 0200
IF-ID-1: enp0s20f0u5c4i2 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:7 chip-ID: 8087:0aa7 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 7 state: up address: <filter>
Local Storage: total: 685.61 GiB used: 581.24 GiB (84.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: RBU-SNS8152S3256GG5
type: SSD serial: <filter> rev: 01.R scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT480M500SSD1
size: 447.13 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: MU03 scheme: MBR
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 201.24 GiB (87.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.55 GiB used: 1.2 GiB (7.7%)
System Temperatures: cpu: 63.0 C pch: 59.5 C mobo: 27.8 C gpu: nvidia
temp: 53 C
Processes: 286 Uptime: 2d 23h 9m wakeups: 22 Memory: 15.55 GiB
used: 6.44 GiB (41.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1811 note: see --pkg apt: 0
pacman: 1803 lib: 513 flatpak: 8 Shell: fish v: 3.4.1 running-in: konsole
inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2021-11-26
Last full system update: 2022-05-07 ↻
