Hey
UPDATE: Seems the issue is with the router, I'm having the same issue in windows 10, but curiously not on my android phone. Sorry for wasting time!
Just installed Garuda, during installation and immediately after 5ghz wifi worked. After install i was prompted to update the system and after that it connects without internet. Is this a driver issue? Can I roll back or update the driver?
I have not attempted any fixes. Trying to figure out how to see drivers etc.
Apologies if this topic already exitsts could not find it. The wifi card is a TP Link AX3000.
Many thanks
pp
terminal output below:
x;XxXB%89b8:b8%b88: OS: Garuda Linux
.8Xxd 8X:. Host: ASUSTeK COMPUTER INC. ROG STRIX B450-F GAMING
.8Xx; 8x:. Kernel: 5.17.9-zen1-1-zen
.tt8x .d x88; Uptime: 1 hour, 43 mins
.@8x8; .db: xx@; Packages: 1762 (pacman)
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Shell: bash
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; DE: Plasma 5.24.5
,888S pd! WM: KWin
8X88/ q WM Theme: Breeze
GBB. Terminal: konsole
x%88 d888@8@X@X@X88X@@XX@@X@8@X. CPU: AMD Ryzen 5 2600X (12) @ 3.6GHz
dxXd dB8b8b8B8B08bB88b998888b88x. GPU: NVIDIA GeForce GTX 1070 Ti
dxx8o .@@;. Memory: 7.16GiB / 15.61GiB
dx88 .t@x.
d:SS@8ba89aa67a853Sxxad.
.d988999889889899dd.
╭─jo@jo in ~
╰─λ garuda-inxi
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=398795f5-8869-4625-85ab-b23cc027e9ba rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4602
date: 08/17/2021
Device-1: hidpp_battery_0 model: Logitech G603 Wireless Gaming Mouse
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 4094 high: 4151 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3776 2: 4150
3: 4150 4: 4146 5: 4150 6: 4147 7: 3886 8: 4148 9: 4146 10: 4134 11: 4149
12: 4151 bogomips: 86402
Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: eVga.com.
driver: nvidia v: 515.43.04 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 09:00.0 chip-ID: 10de:1b82 class-ID: 0300
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-2 res: 2560x1440 dpi: 65024 size: 1x1mm (0.04x0.04")
diag: 1mm (0.06") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 515.43.04 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: eVga.com.
bus-ID: 09:00.1 chip-ID: 10de:10f0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-3: Creative Sound Blaster Premium HD [SBX] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:3 chip-ID: 041e:3232
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
bus-ID: 1-9:5 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 4.11 TiB used: 67.69 GiB (1.6%)
model: WDBRPG0010BNC-WRSN size: 931.51 GiB block-size: physical: 512 B
rev: 111130WD temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-1ER162
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC45
scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 14.41 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> scheme: MBR
used: 67.69 GiB (7.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.61 GiB used: 21.2 MiB (0.1%)
System Temperatures: cpu: 42.0 C mobo: 34.0 C gpu: nvidia temp: 52 C
Fan Speeds (RPM): cpu: 671 case-1: 0 case-2: 761 case-3: 0 gpu: nvidia
fan: 8%
Power: 12v: 9.92 5v: N/A 3.3v: N/A vbat: 3.21
Processes: 390 Uptime: 1h 43m wakeups: 6 Memory: 15.61 GiB
used: 7.18 GiB (46.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1762 lib: 502 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.3-2):
System install date: 2022-05-20
Last full system update: 2022-05-20 ↻
Failed units:~~~
