So I see a new ZEN 5.18 incoming and installed it and rebooted fine, just is causing an issue with my wifi dongle. Upon reboot it tried but failed to activate the dongle. So I restored from a snapshot and back and running. My question is more of if I install the kernel and the same happens again. Would I need to remove the driver and redo the process? Or what other route to get it to launch the driver again?
mkdir -p ~/build
cd ~/build
git clone https://github.com/brektrou/rtl8821CU.git
sudo pacman -S bc dkms
cd ~/build/rtl8821CU
sudo ./dkms-install.sh
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=b4e3b216-a092-473e-8800-311bb9cd5561 rw rootflags=subvol=@
resume=UUID=0a35d60e-8805-41fb-8ce2-ebab30994957 loglevel=3
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.34 info: cairo-dock
wm: gnome-shell dm: GDM v: 42.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P6X58D PREMIUM v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 1501
date: 05/10/2011
Info: model: Intel Core i7 950 bits: 64 type: MT MCP arch: Nehalem
family: 6 model-id: 0x1A (26) stepping: 5 microcode: 0x1D
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1786 high: 2312 min/max: 1600/3068 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1632 2: 1679
3: 1986 4: 1646 5: 1633 6: 1758 7: 1649 8: 2312 bogomips: 49178
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: AMD Cypress XT [Radeon HD 5870] driver: radeon v: kernel
alternate: amdgpu pcie: gen: 2 speed: 5 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DVI-I-1,DVI-I-2 bus-ID: 03:00.0
chip-ID: 1002:6898 class-ID: 0300
compositor: gnome-shell driver: X: loaded: radeon unloaded: modesetting
alternate: fbdev,vesa gpu: radeon display-ID: :1 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-0 model: LG (GoldStar) TV
serial: <filter> built: 2010 res: 1920x1080 dpi: 305 gamma: 1.2
size: 160x90mm (6.3x3.54") diag: 184mm (7.2") ratio: 16:9 modes:
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: AMD Cypress HDMI Audio [Radeon HD 5830/5850/5870 / 6850/6870
Rebrand]
bus-ID: 03:00.1 chip-ID: 1002:aa50 class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
Device-1: Realtek 802.11ac NIC type: USB driver: rtl8821cu bus-ID: 1-4:2
chip-ID: 0bda:c811 class-ID: 0000 serial: <filter>
IF: wlp0s26f7u4 state: up mac: <filter>
Local Storage: total: 2.27 TiB used: 1.71 TiB (75.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: PNY model: CS900 500GB SSD
type: SSD serial: <filter> rev: 0615 scheme: MBR
ID-1: / raw-size: 457.34 GiB size: 457.34 GiB (100.00%)
used: 117.08 GiB (25.6%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 457.34 GiB size: 457.34 GiB (100.00%)
ID-3: /var/log raw-size: 457.34 GiB size: 457.34 GiB (100.00%)
ID-4: /var/tmp raw-size: 457.34 GiB size: 457.34 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.78 GiB used: 760.8 MiB (12.9%)
ID-2: swap-2 type: partition size: 8.42 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 40.0 C mobo: 39.0 C gpu: radeon temp: 45.0 C
Fan Speeds (RPM): cpu: 1278 psu: 0 case-1: 767 case-2: 1068 case-3: 0
Power: 12v: 12.14 5v: N/A 3.3v: 3.20 vbat: N/A
Processes: 290 Uptime: 27m wakeups: 0 Memory: 5.78 GiB
used: 2.95 GiB (51.1%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1596 lib: 377 flatpak: 0 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-04-24
Last full system update: 2022-05-27
Is partially upgraded: Yes
