Hey,
Since 5.16 kernal update, Neither sddm nor xorg would work at startup, Stuck on systemd. I restored from snapper and currently using with 5.15 kernal. I thought it must be fixed from future updates but still its here.
inxi info:
Kernel: 5.16.0-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.23.5 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING PLUS (MS-7C56) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.70
date: 06/23/2021
Info: 12-core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
rev: 0 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB
Speed (MHz): avg: 2760 high: 4344 min/max: 2200/4672 boost: enabled
cores: 1: 4192 2: 2148 3: 4303 4: 4004 5: 2089 6: 2195 7: 2200 8: 2199
9: 2200 10: 2468 11: 2917 12: 2140 13: 4344 14: 2144 15: 4283 16: 2757
17: 2197 18: 2156 19: 2200 20: 2199 21: 2199 22: 4138 23: 2414 24: 2175
bogomips: 182399
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 495.46 bus-ID: 2b:00.0
Display: x11 server: X.Org 1.21.1.3 driver: loaded: nvidia
unloaded: modesetting resolution: 1: 1920x1080 2: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 2b:00.1
driver: snd_hda_intel v: kernel bus-ID: 2d:00.4
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.2:6
Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-5: PipeWire v: 0.3.43 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-2.1:4
Local Storage: total: 1.59 TiB used: 1.05 TiB (66.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 500GB
size: 465.76 GiB temp: 39.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB temp: 31.9 C
ID-3: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
ID-1: / size: 259.52 GiB used: 207.05 GiB (79.8%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 349.3 MiB used: 596 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p3
ID-3: /home size: 259.52 GiB used: 207.05 GiB (79.8%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 259.52 GiB used: 207.05 GiB (79.8%) fs: btrfs
dev: /dev/nvme0n1p2
ID-5: /var/tmp size: 259.52 GiB used: 207.05 GiB (79.8%) fs: btrfs
dev: /dev/nvme0n1p2
ID-1: swap-1 type: zram size: 15.61 GiB used: 6.15 GiB (39.4%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (RPM): cpu: 1883 fan-2: 0 fan-3: 0 fan-4: 0 fan-5: 500
fan-6: 472 fan-7: 0 fan-8: 1091 fan-9: 0 fan-10: 0 gpu: nvidia fan: 12%
Processes: 576 Uptime: 4h 41m Memory: 15.61 GiB used: 12.8 GiB (82.0%)
Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1842
Shell: fish v: 3.3.1 inxi: 3.3.11
