Hi guys, I'm new on using Garuda Linux and I would love some help to setting up my displays.
I want to use two external monitors:
1 - HDMI: which works fine
2 - usbToVga: which is not working
I have read foruns this included and tried a lot o solutions but nothing works for me.
I'm using Optimus Manager (Hybrid mode)
I have a NVidia GTX 1650 and an Intel (discrete)
My inxi output:
╰─λ garuda-inxi
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=4197740c-f66a-4bd7-a7d1-0251511abfcb rw [email protected]
resume=UUID=ebd769b8-157e-414b-a633-17d3e12ca24b loglevel=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Laptop System: LENOVO product: 82CG v: IdeaPad Gaming 3 15IMH05
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15IMH05
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: EGCN33WW date: 12/24/2020
ID-1: BAT0 charge: 44.0 Wh (100.0%) condition: 44.0/45.0 Wh (97.8%)
volts: 12.7 min: 11.4 model: SMP L19M3PF7 type: Li-poly serial: <filter>
status: full cycles: 18
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3978 high: 4488 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 2852 2: 3919 3: 3378
4: 4049 5: 4479 6: 4369 7: 3167 8: 4260 9: 3998 10: 4488 11: 4354
12: 4424 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 510.68.02
alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: none bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-3: DisplayLink Overfly FY-1016A type: USB driver: udl
bus-ID: 1-3:3 chip-ID: 17e9:019e class-ID: 0000 serial: <filter>
Device-4: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:5 chip-ID: 13d3:56ff class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: intel
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 867x285mm (34.13x11.22")
s-diag: 913mm (35.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: primary,left
model: Toshiba Matsushita LCD-MONITOR serial: <filter> built: 2011
res: 1366x768 hz: 60 dpi: 84 gamma: 1.2 size: 413x234mm (16.26x9.21")
diag: 475mm (18.7") ratio: 16:9 modes: max: 1366x768 min: 640x400
Monitor-2: eDP-1 pos: primary,right model: ChiMei InnoLux 0x15e7
built: 2020 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.0.3
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
IF: wlp0s20f3 state: down mac: <filter>
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 0c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp12s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 476.94 GiB used: 48.1 GiB (10.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8L
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: C04C
temp: 33.9 C scheme: GPT
ID-1: / raw-size: 442.3 GiB size: 442.3 GiB (100.00%)
used: 48.1 GiB (10.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 442.3 GiB size: 442.3 GiB (100.00%)
ID-4: /var/log raw-size: 442.3 GiB size: 442.3 GiB (100.00%)
ID-5: /var/tmp raw-size: 442.3 GiB size: 442.3 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.34 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.22 GiB used: 8.63 GiB (27.6%)
System Temperatures: cpu: 68.0 C pch: 58.0 C mobo: N/A
Processes: 554 Uptime: 4d 21h 5m wakeups: 1 Memory: 31.22 GiB
used: 24.21 GiB (77.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1901 lib: 545 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-03-31
Last full system update: 2022-05-10 ↻
This is xrandr output:
Screen 0: minimum 320 x 200, current 3286 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+1366+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 60.00*+ 59.97 59.96 59.93
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DVI-I-2-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 connected 1366x768+0+0 (normal left inverted right x axis y axis) 413mm x 234mm
1366x768 59.79*+
1920x1080 60.00
1360x768 60.02
1280x720 60.00 59.94 50.00
1024x768 75.03 72.00 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
640x400 70.10
1024x768 (0x5f) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x6e) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x6f) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
640x480 (0x7b) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
My dmesg output:
╰─λ sudo dmesg | grep -i usb
[sudo] password for aleks:
[ 0.661915] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.661924] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.661931] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.661958] usbcore: registered new interface driver usbserial_generic
[ 0.661961] usbserial: USB Serial support registered for generic
[ 1.369129] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.370346] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.17
[ 1.370347] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.370348] usb usb1: Product: xHCI Host Controller
[ 1.370349] usb usb1: Manufacturer: Linux 5.17.5-zen1-1-zen xhci-hcd
[ 1.370350] usb usb1: SerialNumber: 0000:00:14.0
[ 1.370409] hub 1-0:1.0: USB hub found
[ 1.370780] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.370782] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.370802] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.17
[ 1.370803] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.370804] usb usb2: Product: xHCI Host Controller
[ 1.370805] usb usb2: Manufacturer: Linux 5.17.5-zen1-1-zen xhci-hcd
[ 1.370805] usb usb2: SerialNumber: 0000:00:14.0
[ 1.370848] hub 2-0:1.0: USB hub found
[ 1.371029] usb: port power management may be unreliable
[ 1.609605] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.746846] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 4.01
[ 1.746849] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.746849] usb 1-1: Product: USB2.0 Hub
[ 1.746850] usb 1-1: Manufacturer: GenesysLogic
[ 1.748130] hub 1-1:1.0: USB hub found
[ 1.854810] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 1.871363] usb 2-1: New USB device found, idVendor=05e3, idProduct=0616, bcdDevice= 4.01
[ 1.871365] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.871366] usb 2-1: Product: USB3.0 Hub
[ 1.871367] usb 2-1: Manufacturer: GenesysLogic
[ 1.872409] hub 2-1:1.0: USB hub found
[ 1.982619] usb 1-3: new high-speed USB device number 3 using xhci_hcd
[ 2.112008] usb 1-3: New USB device found, idVendor=17e9, idProduct=019e, bcdDevice= 1.02
[ 2.112011] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.112012] usb 1-3: Product: USB-DVI
[ 2.112013] usb 1-3: Manufacturer: DisplayLink
[ 2.112014] usb 1-3: SerialNumber: LS2019051217
[ 2.175576] usb 1-1.3: new low-speed USB device number 4 using xhci_hcd
[ 2.258615] usb 1-1.3: New USB device found, idVendor=0c45, idProduct=1111, bcdDevice= 1.05
[ 2.258618] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.258620] usb 1-1.3: Product: USB Gaming Keyboard
[ 2.367582] usb 1-6: new high-speed USB device number 5 using xhci_hcd
[ 2.506421] usb 1-6: New USB device found, idVendor=13d3, idProduct=56ff, bcdDevice=19.19
[ 2.506425] usb 1-6: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2.506427] usb 1-6: Product: Integrated Camera
[ 2.506428] usb 1-6: Manufacturer: Azurewave
[ 2.562580] usb 1-1.4: new low-speed USB device number 6 using xhci_hcd
[ 2.644170] usb 1-1.4: New USB device found, idVendor=18f8, idProduct=0f99, bcdDevice= 1.00
[ 2.644173] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.644175] usb 1-1.4: Product: USB OPTICAL MOUSE
[ 2.754601] usb 1-14: new full-speed USB device number 7 using xhci_hcd
[ 2.881818] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
[ 2.881822] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.902886] input: USB Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:0C45:1111.0002/input/input21
[ 2.935459] usbcore: registered new interface driver udl
[ 2.947575] usbcore: registered new interface driver btusb
[ 2.949443] usb 1-6: Found UVC 1.00 device Integrated Camera (13d3:56ff)
[ 2.953533] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input22
[ 2.955665] hid-generic 0003:0C45:1111.0002: input,hidraw1: USB HID v1.11 Keyboard [USB Gaming Keyboard] on usb-0000:00:14.0-1.3/input0
[ 2.955700] usbcore: registered new interface driver uvcvideo
[ 2.965689] input: USB Gaming Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:0C45:1111.0003/input/input23
[ 3.017739] input: USB Gaming Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:0C45:1111.0003/input/input24
[ 3.017768] input: USB Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:0C45:1111.0003/input/input25
[ 3.017814] hid-generic 0003:0C45:1111.0003: input,hiddev96,hidraw2: USB HID v1.11 Keyboard [USB Gaming Keyboard] on usb-0000:00:14.0-1.3/input1
[ 3.019797] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:18F8:0F99.0004/input/input26
[ 3.019839] hid-generic 0003:18F8:0F99.0004: input,hidraw3: USB HID v1.10 Mouse [USB OPTICAL MOUSE ] on usb-0000:00:14.0-1.4/input0
[ 3.022744] input: USB OPTICAL MOUSE Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:18F8:0F99.0005/input/input27
[ 3.074721] hid-generic 0003:18F8:0F99.0005: input,hiddev97,hidraw4: USB HID v1.10 Keyboard [USB OPTICAL MOUSE ] on usb-0000:00:14.0-1.4/input1
[ 3.074745] usbcore: registered new interface driver usbhid
[ 3.074746] usbhid: USB HID core driver
[423012.805084] usb 1-3: USB disconnect, device number 3
[423027.721369] usb 1-1: USB disconnect, device number 2
[423027.721372] usb 1-1.3: USB disconnect, device number 4
[423027.856452] usb 2-1: USB disconnect, device number 2
[423027.862896] usb 1-1.4: USB disconnect, device number 6
[423055.049755] usb 2-3: new SuperSpeed USB device number 3 using xhci_hcd
[423055.067346] usb 2-3: New USB device found, idVendor=05e3, idProduct=0616, bcdDevice= 4.01
[423055.067349] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[423055.067351] usb 2-3: Product: USB3.0 Hub
[423055.067352] usb 2-3: Manufacturer: GenesysLogic
[423055.068742] hub 2-3:1.0: USB hub found
[423055.177483] usb 1-3: new high-speed USB device number 8 using xhci_hcd
[423055.317060] usb 1-3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 4.01
[423055.317063] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[423055.317064] usb 1-3: Product: USB2.0 Hub
[423055.317065] usb 1-3: Manufacturer: GenesysLogic
[423055.318470] hub 1-3:1.0: USB hub found
[423055.612467] usb 1-3.3: new low-speed USB device number 9 using xhci_hcd
[423055.696023] usb 1-3.3: New USB device found, idVendor=0c45, idProduct=1111, bcdDevice= 1.05
[423055.696027] usb 1-3.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[423055.696028] usb 1-3.3: Product: USB Gaming Keyboard
[423055.703455] input: USB Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.0/0003:0C45:1111.0006/input/input37
[423055.755797] hid-generic 0003:0C45:1111.0006: input,hidraw1: USB HID v1.11 Keyboard [USB Gaming Keyboard] on usb-0000:00:14.0-3.3/input0
[423055.760879] input: USB Gaming Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.1/0003:0C45:1111.0007/input/input38
[423055.812620] input: USB Gaming Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.1/0003:0C45:1111.0007/input/input39
[423055.812716] input: USB Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.1/0003:0C45:1111.0007/input/input40
[423055.812866] hid-generic 0003:0C45:1111.0007: input,hiddev96,hidraw2: USB HID v1.11 Keyboard [USB Gaming Keyboard] on usb-0000:00:14.0-3.3/input1
[423055.881472] usb 1-3.4: new low-speed USB device number 10 using xhci_hcd
[423056.736430] usb 1-3-port4: Cannot enable. Maybe the USB cable is bad?
[423056.803469] usb 1-3.4: new low-speed USB device number 11 using xhci_hcd
[423056.877555] usb 1-3.4: device descriptor read/64, error -71
[423057.055557] usb 1-3.4: device descriptor read/64, error -71
[423057.161419] usb 1-3-port4: attempt power cycle
[423058.320320] usb 1-3-port4: Cannot enable. Maybe the USB cable is bad?
[423058.387563] usb 1-3.4: new low-speed USB device number 13 using xhci_hcd
[423058.387665] usb 1-3.4: Device not responding to setup address.
[423058.591638] usb 1-3.4: Device not responding to setup address.
[423058.799517] usb 1-3.4: device not accepting address 13, error -71
[423058.799992] usb 1-3-port4: unable to enumerate USB device
[423074.925589] usb 1-1: new high-speed USB device number 14 using xhci_hcd
[423075.040607] usb 1-1: device descriptor read/64, error -32
[423075.274527] usb 1-1: New USB device found, idVendor=17e9, idProduct=019e, bcdDevice= 1.02
[423075.274530] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[423075.274531] usb 1-1: Product: USB-DVI
[423075.274532] usb 1-1: Manufacturer: DisplayLink
[423075.274533] usb 1-1: SerialNumber: LS2019051217
[423082.245642] usb 1-3.3: USB disconnect, device number 9
[423090.884549] usb 1-3.3: new low-speed USB device number 15 using xhci_hcd
[423090.967778] usb 1-3.3: New USB device found, idVendor=0c45, idProduct=1111, bcdDevice= 1.05
[423090.967781] usb 1-3.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[423090.967782] usb 1-3.3: Product: USB Gaming Keyboard
[423090.975321] input: USB Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.0/0003:0C45:1111.0008/input/input41
[423091.026764] hid-generic 0003:0C45:1111.0008: input,hidraw1: USB HID v1.11 Keyboard [USB Gaming Keyboard] on usb-0000:00:14.0-3.3/input0
[423091.031882] input: USB Gaming Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.1/0003:0C45:1111.0009/input/input42
[423091.083652] input: USB Gaming Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.1/0003:0C45:1111.0009/input/input43
[423091.083712] input: USB Gaming Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.1/0003:0C45:1111.0009/input/input44
[423091.083833] hid-generic 0003:0C45:1111.0009: input,hiddev96,hidraw2: USB HID v1.11 Keyboard [USB Gaming Keyboard] on usb-0000:00:14.0-3.3/input1
[423091.152551] usb 1-3.4: new low-speed USB device number 16 using xhci_hcd
[423091.235766] usb 1-3.4: New USB device found, idVendor=18f8, idProduct=0f99, bcdDevice= 1.00
[423091.235769] usb 1-3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[423091.235770] usb 1-3.4: Product: USB OPTICAL MOUSE
[423091.243721] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.4/1-3.4:1.0/0003:18F8:0F99.000A/input/input45
[423091.243903] hid-generic 0003:18F8:0F99.000A: input,hidraw3: USB HID v1.10 Mouse [USB OPTICAL MOUSE ] on usb-0000:00:14.0-3.4/input0
[423091.246814] input: USB OPTICAL MOUSE Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.4/1-3.4:1.1/0003:18F8:0F99.000B/input/input46
[423091.298931] hid-generic 0003:18F8:0F99.000B: input,hiddev97,hidraw4: USB HID v1.10 Keyboard [USB OPTICAL MOUSE ] on usb-0000:00:14.0-3.4/input1
[423121.203695] usb 1-1: USB disconnect, device number 14
[423128.457823] usb 1-1: new high-speed USB device number 17 using xhci_hcd
[423128.572845] usb 1-1: device descriptor read/64, error -32
[423128.811831] usb 1-1: New USB device found, idVendor=17e9, idProduct=019e, bcdDevice= 1.02
[423128.811834] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[423128.811835] usb 1-1: Product: USB-DVI
[423128.811836] usb 1-1: Manufacturer: DisplayLink
[423128.811836] usb 1-1: SerialNumber: LS2019051217
I appreciate any help!
Thanks
