3.5mm jacks wont be recognized for microphone
ive searched every where asked discord no response yet
my microphone is not listed on the audio settings its connected via 3.5mm jack
my audio driver is pulseaudio i already tried reinstalling it
Please post your garuda-inxi we do not have enough information to help.
Also Welcome
yes please post your garuda-inxi you open the terminal and type this in and copy the output her with the </> sign.
maybe you try pipewire instead of pulseaudio.I found this guide .i have pipewire installed and all my mics or 3.5 sockets found and working.
  1. Remove PulseAudio : First, remove PulseAudio and its related packages.
sudo pacman -Rs pulseaudio pulseaudio-bluetooth
  1. Install PipeWire : Next, install PipeWire and its related packages.
sudo pacman -S pipewire pipewire-pulse pipewire-alsa wireplumber
  1. Configure PipeWire : To ensure PipeWire works as a PulseAudio replacement, you may need to configure it. This can be done by ensuring the PipeWire PulseAudio compatibility module is enabled. After installation, you can verify this by running:
pactl info
This should indicate that the server name is “PulseAudio (on PipeWire)”.
4. Mask PulseAudio Services : To prevent PulseAudio from starting automatically, mask its services.
systemctl --user mask pulseaudio
systemctl --user mask pulseaudio.socket
  1. Enable and Start PipeWire Services : Enable and start the PipeWire services to ensure they run on boot.
systemctl --user enable --now pipewire
systemctl --user enable --now wireplumber
  1. Reboot : Finally, reboot your system to ensure all changes take effect.
reboot
