I’m having problems with my 3.5mm combo jack. I’m using a headset but the mic on my headset isn’t working. I’ve changed it in the system settings from internal mic to headset mic but no sound comes out. Then I tried to go back to the internal mic on the laptop and it worked. Then I tried to go back to the headset mic but no sound came out. I’ve tried reinstalling the driver and updating the driver. It’s still the same. Please help.
Please can you provide your
As per the forum template
Kernel: 6.11.8-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a7cab5aa-8cd3-4669-9410-ce12ffb28601 rw rootflags=subvol=@
resume=UUID=d8b4a4ee-7e40-4e87-b4da-f22afa834d82 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X409DA_M409DA
Mobo: ASUSTeK model: X409DA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: X409DA.306
date: 10/08/2021
ID-1: BAT0 charge: 20.3 Wh (90.6%) condition: 22.4/32.1 Wh (69.9%)
power: 6.3 W volts: 7.9 min: 7.9 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: charging cycles: 323
Info: model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx bits: 64
Topology: cpus: 1x dies: 1 clusters: 1 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB
desc: 2x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2717 min/max: 1400/2600 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2717 2: 2717 3: 2717
4: 2717 bogomips: 20759
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 80.0 C
Device-2: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.2:6
chip-ID: 13d3:5a11 class-ID: 0e02
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 3 Graphics
(radeonsi raven2 LLVM 18.1.8 DRM 3.59 6.11.8-zen1-2-zen)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 7 device: 0 type: integrated-gpu name: AMD
Radeon Vega 3 Graphics (RADV RAVEN2) driver: mesa radv v: 24.2.7-arch1.1
device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.7-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.11.8-zen1-2-zen status: kernel-api
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.1:5
chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 238.49 GiB used: 43.28 GiB (18.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 119.24 GiB block-size: physical: 512 B
fw-rev: VC2S038E temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Colorful model: SL300 128GB
tech: SSD serial: <filter> fw-rev: 18E3 scheme: GPT
ID-1: / raw-size: 108.32 GiB size: 108.32 GiB (100.00%)
used: 19.12 GiB (17.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 108.32 GiB size: 108.32 GiB (100.00%)
ID-4: /var/log raw-size: 108.32 GiB size: 108.32 GiB (100.00%)
ID-5: /var/tmp raw-size: 108.32 GiB size: 108.32 GiB (100.00%)
ID-1: swap-1 type: zram size: 9.66 GiB used: 50.8 MiB (0.5%) priority: 100
ID-2: swap-2 type: partition size: 10.63 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 89.6 C mobo: N/A gpu: amdgpu temp: 89.0 C
Fan Speeds (rpm): cpu: 2800
Memory: total: 12 GiB note: est. available: 9.66 GiB used: 5.37 GiB (55.6%)
Processes: 266 Power: uptime: 1h 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.85 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1525 libs: 450 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-11-16
Last full system update: 2024-11-19
Failed units:```
This one might be worth a shot: https://wiki.archlinux.org/title/Advanced_Linux_Sound_Architecture#Correctly_detect_microphone_plugged_in_a_4-pin_3.5mm_(TRRS)_jack
Correctly detect microphone plugged in a 4-pin 3.5mm (TRRS) jack
On some modern laptops, you may have a combined 3.5mm headset jack, instead of two separated ones, which may not be correctly detected by default. To make ALSA correctly detect plug-in status on your 3.5mm jack, you can put the following line into your
/etc/modprobe.d/alsa-base.conf
:options snd_hda_intel index=0 model=*your_model_setting*
For a complete list of options to put in
your_model_setting
, see HD-Audio Codec-Specific Models or its source located at/usr/lib/modules/$(uname -r)/build/Documentation/sound/hd-audio/models.rst
(provided by the linux-docs package). A common model isdell-headset-multi
, even if the hardware is not from Dell
This suggestion also appears on the ArchWiki ASUS page: https://wiki.archlinux.org/title/Laptop/ASUS
Add
options snd-hda-intel model=laptop-dmic position_fix=3 ac97_quirck=alc_jack
to/etc/modprobe.d/alsa-base.conf
to get mic and headphone/mic to work
I hope that helps, welcome to the community @Darksteel1891.
is this executed using the terminal or not??
You can use micro
in terminal or kate
to create or edit the file alsa-base.conf
, path to the file is /etc/modprobe.d/
OK, it’s done and it’s working too, thank you for your help, but sometimes I have to remove the 3.5mm jack first so that my headset mic works again, thank you very much
