2nd monitor not picked up at all, and nvidia xserver settings is completely blank besides system info after running garuda-update
I ran a garuda-update in the terminal after noticing Discover was telling me I had 100 out of date packages, but once I booted up I got a login on screen (this is weird because I had auto-login turned on so the only time I should need to use my password is for sudo commands) and then after logging in my 2nd monitor just never turned on when usually it’s on right from boot. My thought is this is a nvidia problem because when I open the Xserver panel for my nvidia drivers ( Proprietary ) I noticed all the options and tabs were gone except system info. I’ve just restored my snapshot from before the update and everything is working fine for now but I would like to know if there is a problem with my system or just nvidia being nvidia. I should also mention the drivers that I was using before the update (and now with my snapshot) is 545.29.06 and the new drivers in Discover that I think garuda was trying to install is 550.54.14-2.
Kernel: 6.7.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=320a3d94-a878-4536-be5a-56311ec1e186 rw rootflags=subvol=@
Type: Desktop System: HP product: HP Pavilion Gaming Desktop 690-00xx v: N/A
Mobo: HP model: 843B v: 00 serial: <superuser required>
part-nu: 5QA71AA#ABA uuid: <superuser required> UEFI: AMI v: F.48
date: 07/27/2022
Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
bogomips: 33599
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Hewlett-Packard
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:2182 class-ID: 0300
Device-2: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 3840x1080 s-dpi: 113 s-size: 863x241mm (33.98x9.49")
s-diag: 896mm (35.28")
Monitor-1: DP-0 pos: primary,left res: 1920x1080 dpi: 93
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 112
size: 435x239mm (17.13x9.41") diag: 496mm (19.54") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.276 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2182
surfaces: xcb,xlib
Device-2: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
Device-3: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
Device-4: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:5
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.7.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: active with: 1: pipewire-media-session
status: active 2: pipewire-alsa type: plugin 3: pw-jack type: plugin
tools: pw-cat,pw-cli
Server-2: PulseAudio v: 17.0 status: active with: pulseaudio-jack
type: module tools: pacat,pactl
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0
vendor: Hewlett-Packard RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 0bda:b00a
Report: hciconfig ID: hci0 rfk-id: 0 state: down
address: <filter>
Info: acl-mtu: 1021:8 sco-mtu: 255:12 link-policy: rswitch hold sniff park
link-mode: peripheral accept
Local Storage: total: 5.24 TiB used: 118.76 GiB (2.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-256G-1006 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20110006 temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NM0024-1HT178
tech: HDD rpm: 7200 serial: <filter> fw-rev: SN02 scheme: GPT
model: WD15EADS-00P8B0 size: 1.36 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A01
scheme: MBR
ID-1: / raw-size: 124.99 GiB size: 124.99 GiB (100.00%)
used: 118.73 GiB (95.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 29.4 MiB (30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 124.99 GiB size: 124.99 GiB (100.00%)
ID-4: /var/log raw-size: 124.99 GiB size: 124.99 GiB (100.00%)
ID-5: /var/tmp raw-size: 124.99 GiB size: 124.99 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.21 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
System Temperatures: cpu: 50.0 C pch: 60.0 C mobo: N/A gpu: nvidia
temp: 43 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 45%
Memory: total: 32 GiB available: 31.21 GiB used: 5.95 GiB (19.1%)
Processes: 341 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
Packages: 2177 pm: pacman pkgs: 2136 libs: 600 tools: octopi,pamac,paru
pm: flatpak pkgs: 41 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-02-25
Last full system update: 2024-03-02
The only method recommended by Garuda to update the system is the terminal.
We only use GUI’s for searching.
In the terminal we use garuda-update, update or upd, all the same, this will catch most problems if needed.
It is recommended to update the system once a week with a rolling distribution.
KDE is also undergoing a major change to Plasma 6.
Probably the latter. It is common for Nvidia drivers to break on version updates. You could hold off on the update for a while and just wait for a fix to come down, or try switching to the LTS kernel for now.
garuda-update linux-lts linux-lts-headers
LTS uses a different kernel version. You can boot with an alternate kernel from the advanced options in the Grub menu.
When you are logged in via wayland no nvidia settings will show up that’s only x11. It’s on nvidia to fix that but I wouldn’t hold my breath.
I don’t use wayland because im not a fan of how it feels for gaming (input lag and just lower fps overall) ive just been using x11
thats what i did i only used the gui in discover to see what nvidia update was the most recent but i updated via garuda-update. thats why im just guessing it’s an nvidia problen
ill probably just hold off for now on updating for now and keep using my system without updating the nvidia drivers.
