I get horizontal bars on my 2nd monitor(Dell, Monitor 1 in inxi) after recent update and restart.
inxi-
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_IN",
LC_NAME = "en_IN",
LC_MONETARY = "en_IN",
LC_PAPER = "en_IN",
LC_IDENTIFICATION = "en_IN",
LC_TELEPHONE = "en_IN",
LC_MEASUREMENT = "en_IN",
LC_TIME = "en_IN.UTF-8",
LC_NUMERIC = "en_IN",
LANG = "en_IN"
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.17.5-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=733f468d-fbc6-45d3-9342-5dbe48047967 rw [email protected]
resume=UUID=733f468d-fbc6-45d3-9342-5dbe48047967 resume_offset=7714074
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A
Mobo: HP model: 8787 v: 22.54 serial: <superuser required> UEFI: AMI
v: F.07 date: 09/16/2020
ID-1: BAT0 charge: 65.4 Wh (100.0%) condition: 65.4/65.4 Wh (100.0%)
volts: 12.6 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: full cycles: 588
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1674 high: 2765 min/max: 1400/2900 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2269 2: 1314
3: 1396 4: 1417 5: 1335 6: 1363 7: 1393 8: 1338 9: 2064 10: 2765 11: 2275
12: 1500 13: 1341 14: 1286 15: 1751 16: 1979 bogomips: 92620
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 510.68.02 alternate: nouveau,nvidia_drm pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: none off: HDMI-A-1 empty: DP-1,DP-2 bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: none
bus-ID: 06:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: Luxvisions Innotech HP Wide Vision HD Camera type: USB
driver: uvcvideo bus-ID: 3-3:3 chip-ID: 30c9:000e class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia alternate: intel
gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1013x316mm (39.88x12.44")
s-diag: 1061mm (41.78")
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: right
model: Dell U2415 serial: <filter> built: 2019 res: 1920x1200 hz: 60
dpi: 94 gamma: 1.2 size: 518x324mm (20.39x12.76") diag: 611mm (24.1")
ratio: 16:10 modes: max: 1920x1200 min: 640x480
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: LG Display 0x05fe
built: 2018 res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.5-zen1-2-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f9 class-ID: 0403
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-2-zen running: yes
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
bus-ID: 3-4:4 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 953.87 GiB used: 195.81 GiB (20.5%)
model: MTFDHBA1T0TDV-1AZ1AABHA size: 953.87 GiB block-size: physical: 512 B
rev: HPS0032 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 300 GiB size: 300 GiB (100.00%) used: 83.62 GiB (27.9%)
used: 64.4 MiB (25.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 300 GiB size: 300 GiB (100.00%)
used: 83.62 GiB (27.9%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 300 GiB size: 300 GiB (100.00%)
ID-5: /var/tmp raw-size: 300 GiB size: 300 GiB (100.00%)
ID-1: swap-1 type: file size: 10 GiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
ID-2: swap-2 type: zram size: 15.06 GiB used: 2.18 GiB (14.5%)
System Temperatures: cpu: 76.0 C mobo: N/A gpu: amdgpu temp: 60.0 C
Fan Speeds (RPM): cpu: 3836 fan-2: 3575
Processes: 443 Uptime: 14m wakeups: 2 Memory: 15.06 GiB
used: 5.7 GiB (37.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1771 lib: 385 Shell: fish
v: 3.4.1 default: Zsh v: 5.8.1 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-07
Last full system update: 2022-05-11
Relevant software: tlp NetworkManager
Snapshots: Timeshift
Failed units: bluetooth-autoconnect.service postgresql.service~~~
screenshot of montor -
How do I resolve this
journalctl logs in comment
