Zoom without sound
Hi
Since some time ago the zoom application has no sound.
It used to, but now it doesn’t.
In the sound volume window, in the applications tab, zoom does not appear when it is running (before it did).
Thank you very much.
λ garuda-inxi
Kernel: 6.12.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f83c7c5a-1e63-42f2-a616-1d35dfeba26d rw rootflags=subvol=@
quiet rd.luks.uuid=d41c618f-f321-41b9-baaa-b47e0281472e
resume=/dev/mapper/luks-d41c618f-f321-41b9-baaa-b47e0281472e loglevel=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Laptop System: HP product: HP Laptop 15-ef2xxx v: N/A
Mobo: HP model: 887A v: 59.25 serial: <superuser required>
part-nu: 612B7LA#ABM uuid: <superuser required> UEFI: AMI v: F.34
date: 07/29/2024
ID-1: BAT0 charge: 41.5 Wh (100.0%) condition: 41.5/41.5 Wh (100.0%)
volts: 12.9 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
status: full
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608107
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 2064 min/max: 400/2100 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2064 2: 2064 3: 2064
4: 2064 5: 2064 6: 2064 7: 2064 8: 2064 9: 2064 10: 2064 11: 2064 12: 2064
bogomips: 50308
Device-1: Advanced Micro Devices [AMD/ATI] Lucienne vendor: Hewlett-Packard
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:164c class-ID: 0300 temp: 54.0 C
Device-2: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3
chip-ID: 30c9:0013 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.1-arch1.3
renoir LLVM 18.1.8 DRM 3.59 6.12.4-zen1-1-zen) device-ID: 1002:164c
API: Vulkan v: 1.4.303 layers: 10 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:164c
Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6
API: ALSA v: k6.12.4-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 0bda:b00e
rfk-block: hardware: no software: no address: <filter> bt-v: 4.2 lmp-v: 8
Local Storage: total: 476.94 GiB used: 391.48 GiB (82.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: OSC model: PCIe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: T1103K0L temp: 44.9 C
ID-1: / raw-size: 60.55 GiB size: 60.55 GiB (100.00%) used: 22.4 GiB (37.0%)
ID-2: /boot/efi raw-size: 1.35 GiB size: 1.35 GiB (99.80%)
used: 584 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 390.62 GiB size: 390.62 GiB (100.00%)
used: 368.36 GiB (94.3%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-967d7b8f-0173-4118-b0f2-193bcd518956
ID-4: /var/log raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
used: 22.4 GiB (37.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
ID-1: swap-1 type: partition size: 24.41 GiB used: 734.6 MiB (2.9%)
mapped: luks-d41c618f-f321-41b9-baaa-b47e0281472e
ID-2: swap-2 type: zram size: 11.01 GiB used: 10.91 GiB (99.1%)
System Temperatures: cpu: 59.6 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 12 GiB note: est. available: 11.01 GiB used: 9.25 GiB (84.0%)
Processes: 584 Power: uptime: 16m states: freeze,mem,disk suspend: s2idle
image: 4.39 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: 2248 pm: pacman pkgs: 2237 libs: 591 tools: octopi,paru
pm: flatpak pkgs: 11 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date:     2024-11-08
Last full system update: 2024-12-10
there is also a regression with plasma where muting one app mutes the others, and unmuting one app unmutes the others.
thanks
Now also happens with brave
