Zen Kernel 6.4.5 fails to build module for xone-dkms, consult log does not generate
Issue:
Zen Kernel 6.4.5 fails to build module for xone-dkms, consult log does not generate.
Error:
warning: xone-dkms-0.3-3.1 is up to date -- reinstalling
resolving dependencies...
Packages (1) xone-dkms-0.3-3.1
Total Installed Size:  0.20 MiB
Net Upgrade Size:      0.00 MiB
(1/1) checking keys in keyring        [####################################################################] 100%
(1/1) checking package integrity        [####################################################################] 100%
(1/1) loading package files        [####################################################################] 100%
(1/1) checking for file conflicts        [####################################################################] 100%
(1/1) checking available disk space        [####################################################################] 100%
(1/2) Performing snapper pre snapshots for the following configurations...
==> root: 1423
(2/2) Remove upgraded DKMS modules
==> dkms remove --no-depmod xone/0.3 -k 6.1.39-1-lts
==> dkms remove --no-depmod xone/0.3 -k 6.2.13-zen-1-zen
==> dkms remove xone/0.3
(1/1) reinstalling xone-dkms        [####################################################################] 100%
( 1/10) Arming ConditionNeedsUpdate...
( 2/10) Install DKMS modules
==> dkms install --no-depmod xone/0.3 -k 6.4.5-zen1-1-zen
Error! Bad return status for module build on kernel: 6.4.5-zen1-1-zen (x86_64)
Consult /var/lib/dkms/xone/0.3/build/make.log for more information.
==> WARNING: `dkms install --no-depmod xone/0.3 -k 6.4.5-zen1-1-zen' exited 10
==> dkms install --no-depmod xone/0.3 -k 6.1.39-1-lts
==> depmod 6.1.39-1-lts
( 3/10) Updating initramfs...
:: Building initramfs for linux-lts (6.1.39-1-lts)
find: '/usr/share/X11/locale/am_ET.UTF-8': No such file or directory
find: '/usr/share/X11/locale/cs_CZ.UTF-8': No such file or directory
find: '/usr/share/X11/locale/el_GR.UTF-8': No such file or directory
find: '/usr/share/X11/locale/fi_FI.UTF-8': No such file or directory
find: '/usr/share/X11/locale/ja_JP.UTF-8': No such file or directory
find: '/usr/share/X11/locale/km_KH.UTF-8': No such file or directory
find: '/usr/share/X11/locale/ko_KR.UTF-8': No such file or directory
find: '/usr/share/X11/locale/pt_BR.UTF-8': No such file or directory
find: '/usr/share/X11/locale/pt_PT.UTF-8': No such file or directory
find: '/usr/share/X11/locale/ru_RU.UTF-8': No such file or directory
find: '/usr/share/X11/locale/sr_RS.UTF-8': No such file or directory
find: '/usr/share/X11/locale/th_TH.UTF-8': No such file or directory
find: '/usr/share/X11/locale/zh_CN.UTF-8': No such file or directory
find: '/usr/share/X11/locale/zh_HK.UTF-8': No such file or directory
find: '/usr/share/X11/locale/zh_TW.UTF-8': No such file or directory
:: Building fallback initramfs for linux-lts (6.1.39-1-lts)
:: Building initramfs for linux-zen (6.4.5-zen1-1-zen)
:: Building fallback initramfs for linux-zen (6.4.5-zen1-1-zen)
( 4/10) Updating linux initcpios...
( 5/10) Foreign/AUR package notification
freetube-bin 0.18.0-1
libhdcd 1.4-2
mullvad-ping 0.4.0-1
needrestart 3.6-2
xwaylandvideobridge-bin j1070555-2
( 6/10) Orphaned package notification...
=> No orphans found.
( 7/10) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/sudoers.pacnew
Please check and merge
( 8/10) Check if daemons need restart after library/binary upgrades
Pending kernel upgrade!
Running kernel version:
  6.1.39-1-lts
Diagnostics:
  The currently running kernel version is not the expected kernel version 6.4.5-zen1-1-zen.
Restarting the system to load the new kernel will not be handled automatically, so you should consider rebooting. [Return]
Failed to check for processor microcode upgrades.
No services need to be restarted.
No containers need to be restarted.
User sessions running outdated binaries:
 jedi @ user manager service: systemd[3782]
No VM guests are running outdated hypervisor (qemu) binaries on this host.
( 9/10) Performing snapper post snapshots for the following configurations...
==> root: 1424
(10/10) Syncing all file systems...
 ╭─jedi@jedi in ~ as 🧙 took 59s
 ╰─λ sudo cat /var/lib/dkms/xone/0.3/build/make.log
cat: /var/lib/dkms/xone/0.3/build/make.log: No such file or directory
 ╭─jedi@jedi in ~ as 🧙 took 17ms
System Information:
 ╭─jedi@jedi in ~ as 🧙 took 9ms
 ╰─λ garuda-inxi
  Kernel: 6.1.39-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=41ba4255-afca-4db8-860f-1f050aa76026 rw rootflags=subvol=@
    quiet rd.luks.uuid=371fe326-f0ea-458f-9627-173095a01c7c quiet
    nvidia_drm.modeset=1 ibt=off
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: 1: GDM
    v: 44.1 2: LightDM v: 1.32.0 note: stopped Distro: Garuda Linux
  Type: Laptop System: Micro-Star product: GP63 Leopard 8RD v: REV:1.0
  Mobo: Micro-Star model: MS-16P6 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends v: E16P6IMS.109 date: 05/22/2019
  ID-1: BAT1 charge: 39.6 Wh (100.0%) condition: 39.6/53.4 Wh (74.2%)
    volts: 12.0 min: 10.9 model: MSI Corp. MS-16P6 type: Li-ion serial: N/A
    status: full
  Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
    Plus serial: <filter> charge: 55% (should be ignored) rechargeable: yes
  Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF2
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 2662 high: 4100 min/max: 800/4100 scaling:
    driver: intel_pstate governor: performance cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 4100 9: 4100 10: 2200 11: 3947 12: 2200
    bogomips: 52815
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
    ports: active: HDMI-A-2 off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
    vendor: Micro-Star MSI driver: nvidia v: 535.86.05
    alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
    class-ID: 0302
  Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:7 chip-ID: 5986:211b
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    display-ID: 0
  Monitor-1: HDMI-A-2 model: NS-39D220NA16 serial: <filter> built: 2015
    res: 1360x768 dpi: 41 gamma: 1.2 size: 698x392mm (27.48x15.43")
    diag: 976mm (38.4") ratio: 16:9 modes: max: 1360x768 min: 720x400
  Monitor-2: eDP-1 model: LG Display 0x0590 built: 2017 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct-render: Yes
  API: ALSA v: k6.1.39-1-lts status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
  Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet
    vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 1969:e0a1 class-ID: 0200
  IF-ID-2: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9
  Local Storage: total: 2.75 TiB used: 1.12 TiB (40.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 40.9 C
  ID-2: /dev/sda maj-min: 8:0 model: SATA SSD size: 953.87 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 61.3 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: PSSD T7 Shield
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    scheme: MBR
  ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
    used: 417.13 GiB (44.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-371fe326-f0ea-458f-9627-173095a01c7c
  ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-4: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-5: /var/tmp raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.19 GiB used: 345.8 MiB (1.1%)
  System Temperatures: cpu: 50.0 C pch: 64.0 C mobo: N/A
  Processes: 401 Uptime: 15h 14m wakeups: 714 Memory: total: 32 GiB
  available: 31.19 GiB used: 6.6 GiB (21.2%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1838 libs: 491 tools: octopi,pamac,paru,yay
  pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16 running-in: gnome-terminal
  inxi: 3.3.28
  System install date:     2023-06-11
  Last full system update: 2023-07-24 ↻
 ╭─jedi@jedi in ~ as 🧙 took 2s
 ╰─λ
https://aur.archlinux.org/packages/xone-dkms#comment-925673
They suggest using the git version or switching to the LTS kernel.
I should have checked that. Sorry. Thanks for the feedback.
 ╭─jedi@jedi in ~ as 🧙 took 7ms
 ╰─λ sudo pacman -Rcns xone-dkms
checking dependencies...
Packages (2) xone-dongle-firmware-0.1-8  xone-dkms-0.3-3.1
Total Removed Size:  0.27 MiB
:: Do you want to remove these packages? [Y/n]
==> root: 1425
(2/2) Remove DKMS modules
==> depmod 6.2.13-zen-1-zen
depmod: ERROR: could not open directory /lib/modules/6.2.13-zen-1-zen: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
==> WARNING: `depmod 6.2.13-zen-1-zen' exited 1
(1/2) removing xone-dkms        [####################################################################] 100%
(2/2) removing xone-dongle-firmware        [####################################################################] 100%
(1/8) Arming ConditionNeedsUpdate...
(2/8) Updating initramfs...
(3/8) Updating linux initcpios...
(4/8) Foreign/AUR package notification
libhdcd 1.4-2
needrestart 3.6-2
(5/8) Orphaned package notification...
(6/8) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/sudoers.pacnew
(7/8) Performing snapper post snapshots for the following configurations...
==> root: 1426
(8/8) Syncing all file systems...
 ╭─jedi@jedi in ~ as 🧙 took 54s
 ╰─λ sudo pacman -S xone-dkms-git
Packages (2) xone-dongle-firmware-0.1-8  xone-dkms-git-0.3.r2.gbbf0dcc-1
Total Download Size:   0.10 MiB
Total Installed Size:  0.27 MiB
:: Retrieving packages...
 xone-dkms-git-0.3.r2.gbbf0dcc-1-x86_64                                                 57.2 KiB  38.1 KiB/s 00:02 [####################################################################] 100%
 xone-dongle-firmware-0.1-8-x86_64                                                      44.0 KiB  68.8 KiB/s 00:01 [####################################################################] 100%
 Total (2/2)        101.2 KiB  24.3 KiB/s 00:04 [####################################################################] 100%
(2/2) checking keys in keyring        [####################################################################] 100%
(2/2) checking package integrity        [####################################################################] 100%
(2/2) loading package files        [####################################################################] 100%
(2/2) checking for file conflicts        [####################################################################] 100%
(2/2) checking available disk space        [####################################################################] 100%
==> root: 1427
(1/2) installing xone-dongle-firmware        [####################################################################] 100%
(2/2) installing xone-dkms-git        [####################################################################] 100%
(1/9) Arming ConditionNeedsUpdate...
(2/9) Install DKMS modules
==> dkms install --no-depmod xone/0.3.r2.gbbf0dcc -k 6.4.5-zen1-1-zen
==> dkms install --no-depmod xone/0.3.r2.gbbf0dcc -k 6.1.39-1-lts
==> depmod 6.4.5-zen1-1-zen
(3/9) Updating initramfs...
(4/9) Updating linux initcpios...
(5/9) Foreign/AUR package notification
libhdcd 1.4-2
needrestart 3.6-2
(6/9) Orphaned package notification...
(7/9) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/sudoers.pacnew
==> root: 1428
 ╭─jedi@jedi in ~ as 🧙 took 1m13s
 ╰─λ
