Installation of brother-dcp165c stops ( same problem with installation of firedragon ).
I don't know what to do.
Here is what I see in the terminal:
[đź”´] Ă— yay brother-dcp165c
1 aur/brother-dcp165c 1.1.2-1 [+0 ~0.00]
Driver for Brother DCP-165C printer
:: Zu installierende Pakete(z.B: 1 2 3, 1-3):
:: 1
:: Löse Abhängigkeiten auf…
:: Berechne Konflikte…
:: Berechne interne Konflikte…
Aur (1) brother-dcp165c-1.1.2-1
:: Weiter ĂĽberprĂĽfen? [J/n]:
:: Lade PKGBUILDs herunter…
(1/1) brother-dcp165c-1.1.2-1 [------------------------------------------------------]
/home/franz/.cache/paru/clone/brother-dcp165c/.gitignore
!.gitignore
!.SRCINFO
!PKGBUILD
!fix_lp.patch
!brother-dcp165c.install
/home/franz/.cache/paru/clone/brother-dcp165c/PKGBUILD
pkgname=brother-dcp165c
pkgver=1.1.2
pkgrel=1
pkgdesc="Driver for Brother DCP-165C printer"
url="https://support.brother.com/g/b/producttop.aspx?c=de&lang=de&prod=dcp165c_all"
license=('custom:brother')
depends=('a2ps' 'cups' 'lib32-gcc-libs' 'lib32-glibc')
optdepends=('brscan3: scanner support.')
install="brother-dcp165c.install"
arch=('i686' 'x86_64')
md5sums=('51b9c8ea31dc37540cb8264bb05ca3f7'
'22a0932c6547a682af4a16fb86100614'
'0bf765de513b8d1e37567ecf2c04897e')
source=(
"fix_lp.patch" \
"https://download.brother.com/welcome/dlf005378/dcp165clpr-1.1.2-2.i386.rpm" \
"https://download.brother.com/welcome/dlf005380/dcp165ccupswrapper-1.1.2-2.i386.rpm"
These ":" is the last thing and besides is the prompt.
What should I do now ?
Here is garuda-inxi for my PC:
â•─[email protected] in ~
╰─λ garuda-inxi
Kernel: 6.1.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7f42a999-aa70-4834-9e29-b02013f3f62b rw [email protected]
loglevel=3 ibt=off
Desktop: Cinnamon v: 5.6.6 tk: GTK v: 3.24.36 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Wortmann_AG product: TERRA_PC v: N/A
serial: <superuser required> Chassis: Gigabyte Technology Co., Ltd. type: 3
Mobo: Gigabyte model: H61M-S2PV serial: <superuser required>
UEFI: American Megatrends v: FH WG date: 04/24/2013
Info: model: Intel Core i3-3220 bits: 64 type: MT MCP arch: Ivy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1599 high: 1600 min/max: 1600/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1600 2: 1597 3: 1600
4: 1600 bogomips: 26341
Device-1: AMD Redwood XT [Radeon HD 5670/5690/5730]
vendor: PC Partner / Sapphire driver: radeon v: kernel alternate: amdgpu
arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm built: 2009-15
pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1,DVI-I-1 bus-ID: 01:00.0 chip-ID: 1002:68d8 class-ID: 0300
temp: 34.0 C
Display: x11 server: X.Org v: 21.1.6 driver: X: loaded: radeon
unloaded: modesetting alternate: fbdev,vesa dri: r600 gpu: radeon
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: HDMI-A-1 mapped: HDMI-0 model: Lenovo LEN L220xwC
serial: <filter> built: 2008 res: 1920x1200 hz: 60 dpi: 103 gamma: 1.2
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
missing.
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: AMD Redwood HDMI Audio [Radeon HD 5000 Series]
vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa60 class-ID: 0403
Sound API: ALSA v: k6.1.4-zen2-1-zen running: yes
Local Storage: total: 704.24 GiB used: 13.84 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7LN256HMJP-00000
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 100Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BD142
type: HDD rpm: 7200 serial: <filter> rev: KC45 scheme: GPT
ID-1: / raw-size: 32.56 GiB size: 32.56 GiB (100.00%)
used: 13.81 GiB (42.4%) fs: btrfs dev: /dev/sdb4 maj-min: 8:20
used: 30.1 MiB (31.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 32.56 GiB size: 32.56 GiB (100.00%)
ID-4: /var/log raw-size: 32.56 GiB size: 32.56 GiB (100.00%)
ID-5: /var/tmp raw-size: 32.56 GiB size: 32.56 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.79 GiB used: 206.5 MiB (5.3%)
ID-2: swap-2 type: partition size: 6.84 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 37.0 C mobo: N/A gpu: radeon temp: 34.0 C
Processes: 236 Uptime: 1h 4m wakeups: 0 Memory: 3.79 GiB
used: 2.29 GiB (60.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1253
libs: 323 tools: paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-12
Last full system update: 2023-01-12 ↻
â•─[email protected] in ~ took 7s
╰─λ
