My garuda-inxi is
╭─leonavis@leonavis274 in ~ as 🧙 took 3s
╰─λ garuda-inxi
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_AG",
LC_NAME = "en_AG",
LC_MONETARY = "en_AG",
LC_PAPER = "en_AG",
LC_IDENTIFICATION = "en_AG",
LC_TELEPHONE = "en_AG",
LC_MEASUREMENT = "en_AG",
LC_TIME = "en_DE.UTF-8",
LC_NUMERIC = "en_AG",
LANG = "en_GB.UTF-8"
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
Kernel: 5.18.15-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=d216e2f9-c931-43ca-8670-f2b5172b1b03 rw rootflags=subvol=@
resume=UUID=10467cbe-370b-4a44-8b00-387651be0571 loglevel=3
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
serial: <superuser required> UEFI: American Megatrends LLC. v: H.H0
date: 05/19/2022
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3882 high: 4450 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4027 2: 4091
3: 4093 4: 3649 5: 3601 6: 3602 7: 3614 8: 4414 9: 4124 10: 4450 11: 3600
12: 3643 13: 4095 14: 3896 15: 3619 16: 3602 bogomips: 124811
protection
always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 2f:00.0 chip-ID: 1002:73bf
Monitor-1: DP-1 mapped: DisplayPort-0 model: MSI MAG271C serial: <filter>
built: 2019 res: 1920x1080 dpi: 82 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 6800 (sienna_cichlid LLVM 14.0.6 DRM 3.46
5.18.15-zen1-1-zen) v: 4.6 Mesa 22.1.4 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 5-3.1:3 pcie: gen: 4 chip-ID: 1b1c:0a6b class-ID: 0300
speed: 16 GT/s serial: <filter> lanes: 16 bus-ID: 2f:00.1
chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Corsair HS80 RGB Wireless Gaming Receiver type: USB
Sound Server-1: ALSA v: k5.18.15-zen1-1-zen running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.73 TiB used: 818.87 GiB (29.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte
model: GP-ASM2NE6500GTTD size: 465.76 GiB block-size: physical: 512 B
rev: EGFM13.0 temp: 46.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO Plus
500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 35.9 C scheme: MBR
ID-3: /dev/nvme2n1 maj-min: 259:6 vendor: Western Digital model: WD BLACK
SN750 SE 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 711240WD
temp: 34.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-1: / raw-size: 431.07 GiB size: 431.07 GiB (100.00%) used: 127.26 GiB
(29.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 431.07 GiB size: 431.07 GiB (100.00%) used: 127.26
GiB (29.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 431.07 GiB size: 431.07 GiB (100.00%) used: 127.26
ID-5: /var/tmp raw-size: 431.07 GiB size: 431.07 GiB (100.00%) used: 127.26
ID-1: swap-1 type: zram size: 31.27 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: 42.4 C mobo: 34.0 C gpu: amdgpu temp: 41.0 C
mem: 42.0 C
Fan Speeds (RPM): fan-1: 807 fan-2: 905 fan-3: 909 fan-4: 703 fan-5: 652
fan-6: 0 fan-7: 0 gpu: amdgpu fan: 0
Processes: 395 Uptime: 13m wakeups: 0 Memory: 31.27 GiB used: 4.85 GiB
(15.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.0 Packages: pacman: 1943 lib: 562 Shell: fish v: 3.5.1
Garuda (2.6.5-1):
System install date: 2022-07-28
Last full system update: 2022-08-03 ↻
Though not sure how that'll help here. ^^ My Yakuake has a weird issue: It doesn't "build up" right, meaning that after pressing F12, first there'll be half of and then like 10ms later it'll be open fully. Which is annoying...
Well in my quest to show you I have learned how to record my screen so here u can see it:
https://www.veed.io/view/645fc95e-9bc7-4179-8baa-b2970aa72a6f
Dunno, probably someone already had the issue and I just couldn't find it. Help would be very much appreciated. Thanks
