XOrg high CPU usage
I'm noticing since a few days; about 15-20% CPU usage from XOrg. I noticed because the fan is a bit noisier than usual, constantly. I've ran the latest updates, rebooted; upon login, it's already taking 15-20%.
Doing a search on the topic; XOrg high cpu usage issues can be hard to diagnose because they're generally caused by other software.
One thing I installed recently taking CPU usage is MegaSync to sync files with cloud storage, so I immediately closed it after login to discard that. Not sure what else would have changed.
Here's my inxi
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 intel_iommu=on
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 43.8 Wh (100.0%) condition: 43.8/58.8 Wh (74.5%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: Full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4386 high: 4705 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 4694 2: 4582 3: 4602
4: 3863 5: 4705 6: 4679 7: 4700 8: 2170 9: 4648 10: 4700 11: 4686
12: 4611 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f15
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1-0 res: 1920x1080 hz: 60 dpi: 40
size: 1210x680mm (47.6x26.8") diag: 1388mm (54.6")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.4
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA TU106 High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.2:4 chip-ID: 08bb:29b0
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF-ID-3: virbr1 state: down mac: <filter>
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 1.63 TiB used: 997.43 GiB (59.9%)
model: PC SN730 SDBQNTY-512G-1014 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3J0
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT275MX300SSD4
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R060 scheme: GPT
ID-1: / raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
used: 170.53 GiB (45.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:2
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
ID-4: /var/log raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 376.95 GiB size: 376.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 65.0 C pch: 63.0 C mobo: N/A
Processes: 356 Uptime: 9h 15m wakeups: 1 Memory: 15.46 GiB
used: 4.17 GiB (27.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1717 lib: 490 Shell: fish
Selecting Optimus Manager -> Integrated brings CPU usage back to normal.
Another problem, and I don't know whether it's related: Virtual Manager with QEMU+KVM no longer boots with GPU Passthrough; but boots without it. it just auto-shuts down.
Interesting -- setting Optimus Manager -> NVidia also fixes the problem. It only happens on Hybrid. This looks like a bad update that has nothing to do with me. And VM with GPU passthrough still doesn't work. Anything I can do?
I can't exactly say what is causing the XOrg high CPU issues, but I know for sure a good number of users are experiencing issues with optimus manager because the dependency list needs updating AUR (en) - optimus-manager
Considering that oversight, I wouldn't doubt that there are other overlooked and under-reported issues with it currently going around as well.
The MESA dependency listed there is installed for me.
But today there is a MESA update; but doesn't fix it. Might indicate that there's work in progress on the MESA side to fix something.
I tried doing a roll-back; but because I already attempted various updates, I got no snapshot left from before the problem occurred... so that's not fixing it either.
Perhaps running the VM with GPU passthrough would give an error indicating something useful; but I can't do the passthrough without killing the user session, so I can't see any error it displays.
This is a known issue with the 495xx driver and happens when you connect an external display to a port wired to the dGPU while in switchable graphics mode.
This might improve with the 510xx beta (which for me works better than 495xx anyway) - I can't remember if I tested hybrid graphics on 510xx; I switched to discrete-only while still on 495.44.
btw do you know what's the difference between running Hybrid vs NVidia? With HDMI display connected, it's running through the GPU anyway. And Optimus Manager keeps NVidia on all the time... so what's the difference? And in what circumstances should I normally keep it to something else than Hybrid?
and how can I install the 510xx beta
btw the other problem with VM, I managed to view the error:
error: Failed to start domain 'win10-gpu'
error: Path '/dev/input/by-id/usb-Logitech_Gaming_Keyboard_G213_167C305A3330-event-kbd' is not accessible: No such file or directory
LOL! I did plug a new keyboard indeed. Dunno if I should laugh or cry. Perhaps cry because I bought a Corsair K95 Platinum XT; the only model that's not suppored on Linux!?
