Hey all,
Just curious what video-linux does under Garuda Settings Manager > Hardware Configuration.
I had to install manually xf86-video-amdgpu package to get Xorg to work with my Freesync monitor (and create a 20-amdgpu.conf file).
When I go to the hardware configuration and install video-linux, it says it fails. It also fails on my laptop with an AMD GPU.
Would doing this have been a better option to do? Is it broken for anyone else? And does it just add the xf86-video-amdgpu package I needed? Or are there specific tweaks that it also completes?
Any feedback appreciated.
Kernel: 5.19.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=ce0c8e7e-d13d-4cd8-b518-cbae2e8e57c3 rw rootflags=subvol=@
quiet
cryptdevice=UUID=8660016a-2edf-437d-8801-38a90288cf8a:luks-8660016a-2edf-437d-8801-38a90288cf8a
root=/dev/mapper/luks-8660016a-2edf-437d-8801-38a90288cf8a quiet splash
lsm=landlock,lockdown,yama,integrity,apparmor,bpf audit=1
Type: Desktop Mobo: Gigabyte model: H510M DS2V v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F13
date: 03/25/2022
Info: model: 11th Gen Intel Core i5-11600KF bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 built: 2021+ process: Intel 14nm family: 6
model-id: 0xA7 (167) stepping: 1 microcode: 0x54
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1334 high: 3900 min/max: 800/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 801 2: 801 3: 3900
4: 800 5: 800 6: 801 7: 1012 8: 801 9: 3900 10: 800 11: 800 12: 800
bogomips: 93888
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Gigabyte
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 03:00.0 chip-ID: 1002:73ff
compositor: kwin_x11 driver: X: loaded: amdgpu gpu: amdgpu display-ID: :0
Monitor-1: DP-2 mapped: DisplayPort-1 model: MSI G241V E2
serial: <filter> built: 2021 res: 1920x1080 dpi: 93 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 6600 (dimgrey_cavefish LLVM 14.0.6 DRM
3.47 5.19.2-zen1-1-zen) v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Gigabyte
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Sound Server-1: ALSA v: k5.19.2-zen1-1-zen running: yes
lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.27 TiB used: 44.22 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S8I40100
temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 9.92 GiB
(2.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-8660016a-2edf-437d-8801-38a90288cf8a
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 752 KiB
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 9.92
GiB (2.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 9.92
ID-5: /var/tmp raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 9.92
ID-1: swap-1 type: zram size: 31.22 GiB used: 512 KiB (0.0%)
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 34.0 C
mem: 32.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 451
Processes: 312 Uptime: 18m wakeups: 0 Memory: 31.22 GiB used: 3.73 GiB
(12.0%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: pacman: 1225 lib: 324 Shell: fish v: 3.5.1
Garuda (2.6.6-1):
System install date: 2022-08-20
Last full system update: 2022-08-20 ↻
Failed units: bluetooth-autoconnect.service systemd-vconsole-setup.service
