Change the app, or read the manual from the app you are using.
But there is maybe a setting missing in your app, but no fails.
I installed flameshot
and removed xfce4-screenshooter
. Is there a way to capture screen by PrtSc button via Flameshot instead of Xfce4-screenshooter? I couldn't find it in the keyboards list for Flameshot
This could help maybe?
How to Add Shortcut Keys in XFCE | Unixmen
And you are correct, now I do see the topic will close after 30mins. First time I see that.
thanks a lot, I figured it out now and Flameshot is awesome. I think Flameshot should replace Xfce4-Screenshooter as the default choice for capturing screen and regions therein. Would give better experience out-of-the box to new users without them having to figure this stuff out
Nice stuff man!
I don't know if Garuda Team can change the default app here but if yes, they might take a look. I think SGS really loves that app too.
Nope,
every Maintainer (Xfce=Yorper) use the software he likes in his DE.
We do not touch his selection
If you want flameshot in your DE use my i3wm
Ok this is part of XFCE selection and not Garuda. Just learned something new.
