Hello -
Successfully compiled the xen packagefile but, when attempting to install, I get a conflict:
/usr/lib/xen/bin/qemu-keymap exists in both 'xen' and 'xen-qemu-builtin'
Has anyone seen this before?
Thanks!
inxi follows
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=3b9b80eb-c443-4d72-874d-e123d33d4568
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
loglevel=3 ibt=off
Desktop: LXQt v: 1.1.0 tk: Qt v: 5.15.4 info: cairo-dock, lxqt-panel wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 82K2 v: IdeaPad Gaming 3 15ACH6
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ACH6
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN serial: <superuser required> UEFI: LENOVO
v: H3CN31WW(V2.01) date: 11/18/2021
ID-1: BAT1 charge: 45.9 Wh (100.0%) condition: 45.9/45.0 Wh (102.0%) volts: 13.1 min: 11.5
model: 0x43 0x65 0x6C 0x78 0x70 0x 0x4C 0x32 0x30 0x43 0x33 0x50 0x4500 type: Li-ion
serial: <filter> status: full cycles: 12
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1843 high: 2942 min/max: 1200/4462 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1874 2: 1785 3: 1916 4: 2080 5: 1916 6: 1916
7: 1560 8: 1848 9: 1637 10: 1269 11: 1283 12: 1917 13: 1915 14: 1912 15: 2942 16: 1725
bogomips: 102206
mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo driver: nvidia v: 515.43.04
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of 2022-05) arch: Ampere
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:25a2 class-ID: 0302
Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:1638 class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 13d3:56ff class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0a81 built: 2021 res: 1920x1080 hz: 120 dpi: 142
gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080
min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.46 5.18.1-zen1-1-zen) v: 4.6 Mesa 22.1.1
direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_sof_amd_renoir
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Leno
vo driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter vendor: Lenovo
driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0
chip-ID: 10ec:8852 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Local Storage: total: 534.24 GiB used: 22.96 GiB (4.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HBLU-00BL2 size: 476.94 GiB
rev: 5L2QFXM7 temp: 26.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: USB 3.2Gen1 size: 57.3 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 474.69 GiB size: 474.69 GiB (100.00%) used: 22.96 GiB (4.8%) fs: btrfs
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%) used: 576 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 474.69 GiB size: 474.69 GiB (100.00%) used: 22.96 GiB (4.8%) fs: btrfs
ID-4: /var/log raw-size: 474.69 GiB size: 474.69 GiB (100.00%) used: 22.96 GiB (4.8%)
fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-5: /var/tmp raw-size: 474.69 GiB size: 474.69 GiB (100.00%) used: 22.96 GiB (4.8%)
ID-1: swap-1 type: zram size: 13.57 GiB used: 18.2 MiB (0.1%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 60.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
Processes: 365 Uptime: 13h 32m wakeups: 1 Memory: 13.57 GiB used: 3.45 GiB (25.4%) Init: systemd
v: 251 tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1578 lib: 360
Client: shell wrapper v: 5.1.16-release inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-06-04
Last full system update: 2022-06-05 ↻
