XDG_RUNTIME_DIR is not set
Just installed the latest ISO of hyprland community edition (231029), all good until I reach the sddm and can’t login (tried my user and root and both desktop session with no results), so I reboot an do a recovery session but trying to start from terminal with “Hyprland” or “hyprstart” results on "XDG_RUNTIME_DIR is not set Aborted (core dumped) ". I have installed sway and kde editions before with no problema. What should I do guys?. :confused:
✦ [🔴] × garuda-inxi
    lang=en_US keytable=latam tz=UTC lang=en_US keytable=latam
    tz=America/Mexico_City misobasedir=garuda
    root=miso:LABEL=GARUDA_HYPRLAND_RAPTOR quiet systemd.show_status=1
    ibt=off driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
    rdinit=/vtoy/vtoy
  Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 2103 date: 09/30/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
  Info: model: 13th Gen Intel Core i5-13600K bits: 64 type: MST AMCP
    microcode: 0x119
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 20 MiB desc: 6x2 MiB, 2x4 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 830 high: 1100 min/max: 800/5100:5200:4000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1100 2: 800 3: 1100
    4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
    14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 139776
  Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 03:00.0
    chip-ID: 1002:73ef class-ID: 0300
    compositor: Hyprland driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 1
  Monitor-1: DP-1 model: Dell S3422DWG serial: <filter> built: 2023
    res: 3440x1440 hz: 60 dpi: 110 gamma: 1.2 scale: 1
    size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
    min: 720x400
  API: Vulkan v: 1.3.269 layers: 3 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6650 XT (RADV NAVI23) driver: mesa radv v: 23.2.1-arch1.2
    device-ID: 1002:73ef surfaces: xcb,xlib,wayland device: 1 type: cpu
  Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
  Device-3: FiiO [] driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-5:5 chip-ID: 2972:0047 class-ID: fe01
  Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0 chip-ID: 8086:15f3
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
    class-ID: 0104
  Local Storage: total: 8.46 TiB used: 0 KiB (0.0%)
    model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 731030WD temp: 36.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
    fw-rev: 731030WD temp: 46.9 C scheme: GPT
  ID-3: /dev/nvme2n1 maj-min: 259:8 vendor: MSI model: M461 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: ELFMC1.0 temp: 42.9 C
  ID-4: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD42PURZ-85B4YY0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5040 serial: <filter>
    fw-rev: 0A80 scheme: GPT
  ID-5: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU800 size: 238.47 GiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 1A scheme: GPT
  ID-6: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500413AS
    tech: HDD rpm: 7200 serial: <filter> fw-rev: JC45 scheme: MBR
  ID-7: /dev/sdd maj-min: 8:48 vendor: A-Data model: SU800 size: 476.94 GiB
    serial: <filter> fw-rev: 8B scheme: MBR
  ID-8: /dev/sde maj-min: 8:64 vendor: Kingston model: DataTraveler 3.0
    size: 28.9 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: PMAP scheme: MBR
  ID-1: swap-1 type: zram size: 31.08 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
  System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
    mem: 38.0 C
  Processes: 367 Uptime: 2m wakeups: 12 Memory: total: 32 GiB note: est.
  available: 31.09 GiB used: 3.86 GiB (12.4%) Init: systemd v: 254
  pm: pacman pkgs: 1228 libs: 356 tools: paru Shell: fish v: 3.6.1
  running-in: foot inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2023-10-30
  Last full system update: 2023-10-30 ↻
After
Did you check sha-sum?
Did you use ventoy?
Did you use secure remove USB-Stick on your file browser?
Yesterday I install hyprland on my notebook without problems, AMD CPU and iGPU.
The recovery session was after installation was successful, I entered via the Grub to a terminal, I used Ventoy as always and tried grub2 and normal mode also.
As you suggest will try to download again the ISO and sha-sum it! Will report back tomorrow!
EDIT… there was a mismatch on the checksum, I downloaded it again and the problem is gone! Thanks!
