Also try other usb ports, reconnect controller. The usual…
I am using the Wireless controller straight with USB cabel.
I have to start the service every time i start my PC or otherwise my controller is seen as a gc101 and the button layout is all wrong, so maybe that will help you as well.
sudo systemctl start xboxdrv.service
You can configure a service to start automatically every time you start your computer by using systemd’s “enable
” function like so:
sudo systemctl enable xboxdrv.service
You can also simultaneously start and enable a service by adding the “--now
” flag.
sudo systemctl enable --now xboxdrv.service
Once it is enabled, you shouldn’t have to start it anymore–it will start up on it’s own.
