X Error of failed request: BadValue (integer parameter out of range for operation)
Hi. I has a error with launch Pathfinder: Kingmaker on my pc: “X Error of failed request: BadValue (integer parameter out of range for operation)” with prime-run. I also tried to launch glxinfo and got same error.
My garuda-inxi output
root=UUID=1aad35f5-210c-4a9d-9e0d-add10435614d rw rootflags=subvol=@
Type: Laptop System: HP product: HP Pavilion Notebook
Mobo: HP model: 845E v: 83.62 serial: <superuser required> UEFI: Insyde
v: F.61 date: 03/29/2018
ID-1: BAT0 charge: 43.9 Wh (100.0%) condition: 43.9/43.9 Wh (100.0%)
volts: 12.5 min: 10.9 model: HP Primary type: Li-ion serial: N/A
status: full
Device-1: hidpp_battery_3 model: Logitech G305 Lightspeed Wireless Gaming
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
desc: 1x6 MiB
Speed (MHz): avg: 1100 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 1100 2: 1100 3: 1100 4: 1100 bogomips: 19999
Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Hewlett-Packard driver: nvidia v: 545.29.02
2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0302
Device-3: Chicony HP Wide Vision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04f2:b56d
class-ID: 0e02
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: primary,left res: 1920x1080 dpi: 305
size: 160x90mm (6.3x3.54") diag: 184mm (7.23") modes: N/A
Monitor-2: eDP-1 pos: right res: 1920x1080 hz: 60 dpi: 128
size: 382x215mm (15.04x8.46") diag: 438mm (17.26") modes: N/A
device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: swrast x11:
drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 15.15 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 10 device: 0 type: integrated-gpu
name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:591b surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-3: FiiO BTR5 driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:56
chip-ID: 2972:0047 class-ID: 0300
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 8087:0a2a
Local Storage: total: 1.03 TiB used: 360.57 GiB (34.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD9SN8W-128G-1006
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3006 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-1: / raw-size: 77.63 GiB size: 77.63 GiB (100.00%)
used: 76.52 GiB (98.6%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 390.62 GiB size: 390.62 GiB (100.00%)
used: 284.05 GiB (72.7%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-4: /var/log raw-size: 77.63 GiB size: 77.63 GiB (100.00%)
ID-5: /var/tmp raw-size: 77.63 GiB size: 77.63 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.51 GiB used: 830.8 MiB (5.2%)
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 61.0 C pch: 51.5 C mobo: N/A
Processes: 300 Uptime: 4h 56m wakeups: 0 Memory: total: 16 GiB
available: 15.51 GiB used: 3.76 GiB (24.2%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 12
clang: 16.0.6 Packages: pm: pacman pkgs: 1736 libs: 495
tools: octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.2.21
Garuda (2.6.19-2):
System install date:     2023-08-13
Last full system update: 2023-11-25 ↻
Try rebooting.
Your Nvidia drivers should have been updated.
Should be 545.29.06-1 I think.
It is help. Thank you))
