I'm using Garuda Xfce and when I attempt to shut it down the first time it goes to the desktop, only until I try again will it work?
I've searched for a similar topic but found none with this issue.
Thanks.
Thanks.
Hopefully, someone pops by with a better suggestion; but...
Have your tried adding a shutdown shortcut to your panel or dock? One you can just left click on once to shutdown w/out using a menu to get to it; or is that what you're using?
Pending a better suggestion, you could always use (from terminal):
shutdown now
^^ to shutdown; or...
shutdown -r now
^^ to reboot.
best wishes @BrunoCGL
It should work OOTB. Check troubleshooting methods
https://wiki.archlinux.org/title/Xfce#Suspend
https://man.archlinux.org/man/xfce4-session-logout.1
In standard Arch installation, you don’t need sudo
for such.
