on login state with no users logged in, the screen does not go to sleep
ref:
Anyone knows how to solve this for garuda Hyprland
ref:
This is already your third help request without garuda-inxi
, so please post your garuda-inxi
as requested by the template.
It would also be useful to share what you have already done to fix the issue.
Since we have zero information from you: Have you tried the workaround on github with swayidle
yes I tried with the swayidle but if you are not logged in swayidle won’t work because swayidle expects Wayland to be loaded and it is not at that stage, what I did now to get closer to a working solution was uninstall sddm so i get into bash when I boot then I can run this command “setterm --powersave powerdown --blank force” which effectively turns off the output, and this is where I am at the moment, trying to create a service that shuts down the output when there is no user input, without much success I have to say
did you checked this one?
https://www.reddit.com/r/hyprland/comments/158jyiv/automatically_suspend_and_hibernate/
