I am running the KDE Dragonized version on my laptop and desktop. On both systems, every once in a while the AppMenu moves from the left to the right, next to Flameshot. I have to edit the top panel and drag the AppMenu to the left. A day or two later, the AppMenu is back in the right side. Here is the laptop info:
Kernel: 5.11.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=cc1207ad-2e89-4c11-af1f-337e73c2dc65 rw [email protected] quiet
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Garuda Linux
Type: Laptop System: LENOVO product: 81SS v: Lenovo IdeaPad FLEX-14API
serial: <filter> Chassis: type: 10 v: Lenovo IdeaPad FLEX-14API
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
UEFI: LENOVO v: AGCN27WW(V1.10) date: 07/08/2020
ID-1: BAT1 charge: 26.4 Wh condition: 43.8/45.0 Wh (97%) volts: 15.2/15.4
model: 0x53 0x4D 0x50 0x00 0x32 0x30 0x 0x4C 0x31 0x38 0x4D 0x34 0x50 0x4500
type: Li-ion serial: <filter> status: Discharging cycles: 34
Memory:
RAM: total: 9.72 GiB used: 3.39 GiB (34.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 17 (23)
model-id: 18 (24) stepping: 1 microcode: 8108102 L2 cache: 2 MiB
bogomips: 33537
Speed: 1397 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1384 4: 1232 5: 1264 6: 1222 7: 1221 8: 1221
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
disabled, RSB filling
Device-1: AMD Picasso vendor: Lenovo driver: amdgpu v: kernel
bus ID: 04:00.0 chip ID: 1002:15d8 class ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus ID: 1-4:2
chip ID: 174f:2426 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.11.4-zen1-1-zen LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 1002:15de
class ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x bus ID: 04:00.5
chip ID: 1022:15e2 class ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 04:00.6 chip ID: 1022:15e3 class ID: 0403
Sound Server: ALSA v: k5.11.4-zen1-1-zen
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Lenovo ThinkPad E595 driver: rtw_8822be v: N/A modules: rtw88_8822be
port: 2000 bus ID: 02:00.0 chip ID: 10ec:b822 class ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
WAN IP: <filter>
Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus ID: 3-2:3 chip ID: 0bda:b023 class ID: e001 serial: <filter>
Message: Required tool hciconfig not installed. Check --recommends
Message: No RAID data was found.
Local Storage: total: 476.94 GiB used: 105.8 GiB (22.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 32B3T8EA temp: 28.9 C
Message: No Optical or Floppy data was found.
ID-1: / raw size: 238.46 GiB size: 238.46 GiB (100.00%)
used: 14.86 GiB (6.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: cc1207ad-2e89-4c11-af1f-337e73c2dc65
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%)
used: 38.4 MiB (15.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: 265A-8DEE
ID-3: /home raw size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-4: /root raw size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-5: /run/media/carlos/Windows-SSD raw size: 237.23 GiB
size: 237.23 GiB (100.00%) used: 90.91 GiB (38.3%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows-SSD uuid: 3CD65BBBD65B73DC
ID-6: /srv raw size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-7: /var/cache raw size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-8: /var/log raw size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-9: /var/tmp raw size: 238.46 GiB size: 238.46 GiB (100.00%)
ID-1: swap-1 type: zram size: 1.22 GiB used: 0 KiB (0.0%) priority: 32767
Unmounted:
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: WINRE_DRV
uuid: 842E5C3D2E5C2B06
USB:
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-4:2 info: Syntek Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 174f:2426 class ID: 0e02
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 05e3:0608 class ID: 0900
Device-1: 3-1.2:4 info: Shenzhen Goodix Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 27c6:55b4 class ID: ef00
Device-2: 3-2:3 info: Realtek RTL8822BE Bluetooth 4.2 Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.4 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 294 Uptime: 2h 22m wakeups: 5 Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1424 lib: 329 Shell: fish
v: 3.1.2 running in: konsole inxi: 3.3.01
