tbg
29 June 2021 15:32
41
Simply open add/remove software and type "anbox" in the search field. Obviously it is installed, so simply select to remove it in the Pamac GUI.
Once it is uninstalled reboot and run the last command again to check if the anbox-container-manager.service is now gone.
tbg
29 June 2021 15:37
42
Just a question.
Did you specifically install anbox?
I might have chose that in post install with Garuda Assistant.
I cannot find 'add/remove software' anywhere. Is this something that needs to be installed?
In terminal
sudo pacman -R anbox
[sudo] password for rr:
error: target not found: anbox
tbg
29 June 2021 15:50
44
I think it may be anbox-git you need to uninstall. That package is in the AUR or possibly Chaotic-AUR.
I am only currently on my cell, so it is much harder to check on these things.
sudo pacman -R anbox-git
checking dependencies...
:: removing anbox-git breaks dependency 'anbox-git' required by anbox-support
tbg
29 June 2021 15:53
46
I am going to have contact the Devs. This could possibly be an unexpected side effect of recent changes.
OK, thanks. Post it when you get reply.
tbg
29 June 2021 16:12
48
In the interim, until a full answer is forthcoming you can disable the anbox service from running.
sudo systemctl disable --now anbox-container-manager.service
Also:
sudo systemctl --global disable --now anbox-session-manager
Please post the output if there are any errors from those commands. After running those commands do a reboot (not strictly required), then try to get your wifi working again.
Removed /etc/systemd/system/multi-user.target.wants/anbox-container-manager.service.
Failed to connect to bus: $DBUS_SESSION_BUS_ADDRESS and $XDG_RUNTIME_DIR not defined (consider using --machine=<user>@.host --user to connect to bus of other user)
tbg
29 June 2021 16:47
50
The second command I am not super familiar with global settings, so I will discuss that with Devs.
Please restart and post:
inxi -n
tbg:
inxi -n
after reboot
inxi -n
Network: Device-1: Intel Ethernet I219-V driver: e1000e
IF: eno1 state: up speed: 100 Mbps duplex: full mac: 2c:f0:5d:a4:fd:b8
Device-2: Intel Wireless-AC 9260 driver: iwlwifi
Device-3: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
IF-ID-1: anbox0 state: down mac: 12:16:ac:18:1f:d8
tbg
29 June 2021 16:56
52
Time for the hatchet then.
Try:
sudo pacman -Rns anbox-support anbox-git
I'm not sure if that will fail because of other interdependencies or not (guess we'll find out).
Packages (4) anbox-image-gapps-magisk-2018.07.19-17 lxc-git-4.0.0.r1702.gf1c64634c-1
anbox-git-1:r1348.ad377ff-1 anbox-support-1.1.0-1
Total Removed Size: 467.54 MiB
:: Do you want to remove these packages? [Y/n] Y
(1/4) removing anbox-support [------------------------------------] 100%
(2/4) removing anbox-git [------------------------------------] 100%
(3/4) removing lxc-git [------------------------------------] 100%
(4/4) removing anbox-image-gapps-magisk [------------------------------------] 100%
( 1/11) Syncing all file systems...
( 2/11) Reloading system manager configuration...
( 3/11) Reloading device manager configuration...
( 4/11) Arming ConditionNeedsUpdate...
( 5/11) Refreshing PackageKit...
( 6/11) Foreign/AUR package notification
=> No foreign/AUR packages found.
( 7/11) Orphaned package notification...
ddcutil 1.1.0-1
( 8/11) Checking for .pacnew and .pacsave files...
( 9/11) Updating pkgfile database...
(10/11) Updating the desktop file MIME type cache...
(11/11) Syncing all file systems...
after reboot
inxi -n
tbg
29 June 2021 17:06
56
Much better.
Is your adapter showing up on your taskbar now with WiFi AP's showing?
In Network Assistant WiFi shows enabled. But in top right corner where connections are I still see only wired connection
tbg
29 June 2021 17:11
58
This is much progress.
Unfortunately. I no longer have more time to work on this.
I'm sure this can be made workable now. I just don't have any more time for this today.
