Hello.
I have been using garuda for 7 months
and i’m loving it, except its “hardware bug” on computer
I’m using it as my main OS, i have no windows or other OS on my computer,
I’m using zen kernel cuz its default kernel
idk if it was my fault or either my hardware (laptop) is bad match for arch after all, my friend using garuda GNOME and nothing such like this happened
I 'm literally crying cuz of these bug.
- Wifi not working
wifi could not be figured
i have to restart mylaptop like 5-8 times. and waiting for my luck come to me and then the wifi would magically work
i’ve experienced this since first time i’am using garuda, yes it was annoyed me but sometimes my wifi is stable and sometimes is not, idk why too,
- Audio Problem
i never experienced this before, i have been using garuda for like 7 months but idk why this bug appeared on my laptop, i can’t do nothing for this bug, my speaker and microphone has gone for 2 days,and this bug literally push me for post this thread to this forum
- Camera problem
Same as audio problem, my webcam was working fine for 7 months of using garuda, then this bug is appearing making my webcam also death, icant do presentation for g-meet
- Touchpad Problem
sometimes my touchpad is not found, i just restarted my laptop and the touchpad was working fine, i’ve experienced this for first time using garuda.
- SMPlayer and Youtube Problem
Yo this is also makes me mad and confused, why my SMPlayer can’t play video?
as same as audio and camera problem, I never experienced this bug before, these bug audio-camera-video is new things for me and my laptop, my laptop was working fine for 7 months and idk why suddenly i can’t use my hardware properly
this is the log for SMPlayer:
/usr/bin/mpv --no-config --no-quiet --terminal --no-msg-color --input-ipc-server=/tmp/smplayer-mpv-d37d --msg-level=ffmpeg/demuxer=error --video-rotate=no --no-fs --hwdec=no --sub-auto=fuzzy --no-input-default-bindings --input-x11-keyboard=no --no-input-cursor --cursor-autohide=no --no-keepaspect --wid=90177553 --monitorpixelaspect=1 --osd-level=1 --osd-scale=1 --sub-ass --embeddedfonts --ass-line-spacing=0 --sub-scale=1 --sub-text-shadow-color=#ff000000 --sub-codepage=ISO-8859-1 --sub-pos=100 --volume=58 --cache=auto --screenshot-template=cap_%F_%p_%02n --screenshot-format=jpg --softvol=yes --softvol-max=110 --term-playing-msg=MPV_VERSION=${=mpv-version:}
INFO_VIDEO_WIDTH=${=width}
INFO_VIDEO_HEIGHT=${=height}
INFO_VIDEO_ASPECT=${=video-params/aspect}
INFO_VIDEO_FPS=${=container-fps:${=fps}}
INFO_VIDEO_FORMAT=${=video-format}
INFO_VIDEO_CODEC=${=video-codec}
INFO_DEMUX_ROTATION=${=track-list/0/demux-rotation}
INFO_AUDIO_FORMAT=${=audio-codec-name}
INFO_AUDIO_CODEC=${=audio-codec}
INFO_AUDIO_RATE=${=audio-params/samplerate}
INFO_AUDIO_NCH=${=audio-params/channel-count}
INFO_LENGTH=${=duration:${=length}}
INFO_DEMUXER=${=current-demuxer:${=demuxer}}
INFO_SEEKABLE=${=seekable}
INFO_TITLES=${=disc-titles}
INFO_CHAPTERS=${=chapters}
INFO_TRACKS_COUNT=${=track-list/count}
METADATA_TITLE=${metadata/by-key/title:}
METADATA_ARTIST=${metadata/by-key/artist:}
METADATA_ALBUM=${metadata/by-key/album:}
METADATA_GENRE=${metadata/by-key/genre:}
METADATA_DATE=${metadata/by-key/date:}
METADATA_TRACK=${metadata/by-key/track:}
METADATA_COPYRIGHT=${metadata/by-key/copyright:}
INFO_MEDIA_TITLE=${=media-title:}
INFO_STREAM_PATH=${stream-path}
--audio-client-name=SMPlayer --term-status-msg=STATUS: ${=time-pos} / ${=duration:${=length:0}} P: ${=pause} B: ${=paused-for-cache} I: ${=core-idle} VB: ${=video-bitrate:0} AB: ${=audio-bitrate:0} /home/gusanwa/Downloads/Responsive CSS Grid Tutorial.mp4
Warning: option --input-x11-keyboard was replaced with --input-vo-keyboard and might be removed in the future.
Warning: option --ass-line-spacing was replaced with --sub-ass-line-spacing and might be removed in the future.
Warning: option --sub-text-shadow-color was replaced with --sub-shadow-color and might be removed in the future.
Error parsing option softvol (option not found)
Setting commandline option --softvol=yes failed.
Exiting... (Fatal error)
- I can’t even play video on youtube
As same as audio,camera,video errorrs, i never experienced this before, My wifi was working, i can googling and did intenet stuff, but why i can’t play video even on youtube, and idk why this happened on me, i’ve experinced this for 2 days
i started to think maybe my laptop just bad match for arch,
How to troubleshoot or just fix these problem? i did sudo pacman -Syu to keep my OS updated but the update can’t fix this issues
Can i got some help or i just really give up on arch based distro?
BIG THANKS, and hello
This is my output for my termina; after doing:
inxi -Fxxxxza
lsmod | sort
System: Kernel: 5.10.75-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=14de686a-98f6-4d38-81f0-6f72b6adc4dd rw
systemd.unified_cgroup_hierarchy=1 resume=UUID=64e4a125-b16f-4c98-8693-d00d9127f43c loglevel=3
sysrq_always_enabled=1 mitigations=off
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Acer product: Aspire A315-41 v: V1.18 serial: <filter>
Mobo: RR model: Metapod_RR v: V1.18 serial: <filter> UEFI: Insyde v: 1.18 date: 06/18/2020
Battery: ID-1: BAT1 charge: 7.1 Wh (24.8%) condition: 28.6/36.7 Wh (77.9%) volts: 10.7 min: 11.4
model: LG 0x41,0x43,0x31,0x34,0x42,0x31,0x00B1 type: Li-ion serial: <filter> status: Discharging
CPU: Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 11 (17) stepping: 0 microcode: 810100B cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31938
Speed: 1595 MHz max: 1600 MHz boost: enabled Core speeds (MHz): 1: 1595 2: 1594 3: 1592 4: 1595 5: 1588 6: 1592
7: 1595 8: 1595
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and usercopy barriers only; no swapgs barriers
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Acer Incorporated ALI
driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:15dd class-ID: 0300
Device-2: Quanta VGA WebCam type: USB driver: uvcvideo bus-ID: 3-1:2 chip-ID: 0408:a031 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0 5.10.75-1-lts LLVM 12.0.1) v: 4.6 Mesa 21.2.4
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.75-1-lts running: yes
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.39 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8168
v: 8.049.02-NAPI modules: r8169 port: 2000 bus-ID: 01:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f1 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lite-On driver: ath10k_pci v: kernel
bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Bluetooth: Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 04ca:3015 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Drives: Local Storage: total: 238.47 GiB used: 92.32 GiB (38.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: V-Gen model: 12SM20AR256SDKM2 256GB size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0A0 scheme: GPT
Partition: ID-1: / raw-size: 229.42 GiB size: 229.42 GiB (100.00%) used: 92.32 GiB (40.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 229.42 GiB size: 229.42 GiB (100.00%) used: 92.32 GiB (40.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 229.42 GiB size: 229.42 GiB (100.00%) used: 92.32 GiB (40.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw-size: 229.42 GiB size: 229.42 GiB (100.00%) used: 92.32 GiB (40.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
ID-2: swap-2 type: zram size: 6.75 GiB used: 734 MiB (10.6%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 49.8 C mobo: N/A gpu: amdgpu temp: 49.0 C
Info: Processes: 334 Uptime: 1h 37m wakeups: 3 Memory: 6.75 GiB used: 3.21 GiB (47.5%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1786 lib: 380 Shell: fish (su) v: 3.3.1
running-in: konsole inxi: 3.3.08
ac97_bus 16384 1 snd_soc_core
acer_wireless 20480 0
acer_wmi 28672 0
acpi_cpufreq 28672 0
aesni_intel 372736 5
af_alg 32768 6 algif_hash,algif_skcipher
agpgart 53248 5 intel_agp,intel_gtt,ttm,nouveau,drm
algif_hash 16384 1
algif_skcipher 16384 1
amdgpu 6545408 51
ath10k_core 643072 1 ath10k_pci
ath10k_pci 57344 0
ath 36864 1 ath10k_core
atkbd 36864 0
blake2b_generic 20480 0
bluetooth 704512 45 btrtl,btintel,btbcm,bnep,btusb,rfcomm
bnep 28672 2
bpf_preload 16384 0
btbcm 16384 1 btusb
btintel 32768 1 btusb
btrfs 1585152 1
btrtl 24576 1 btusb
btusb 65536 0
ccm 20480 3
ccp 118784 1 kvm_amd
cec 61440 2 drm_kms_helper,i915
cfg80211 983040 3 ath,mac80211,ath10k_core
cmac 16384 2
crc16 16384 1 bluetooth
crc32c_generic 16384 0
crc32c_intel 24576 2
crc32_pclmul 16384 0
crct10dif_pclmul 16384 1
cryptd 24576 3 crypto_simd,ghash_clmulni_intel
crypto_simd 16384 1 aesni_intel
crypto_user 20480 0
dm_mod 163840 0
drm 577536 19 gpu_sched,drm_kms_helper,amdgpu,radeon,i915,ttm,nouveau
drm_kms_helper 278528 4 amdgpu,radeon,i915,nouveau
ecc 36864 1 ecdh_generic
ecdh_generic 16384 1 bluetooth
edac_mce_amd 32768 0
fat 86016 1 vfat
fb_sys_fops 16384 1 drm_kms_helper
fuse 167936 3
ghash_clmulni_intel 16384 0
glue_helper 16384 1 aesni_intel
gpu_sched 49152 1 amdgpu
hid_multitouch 32768 0
i2c_algo_bit 16384 4 amdgpu,radeon,i915,nouveau
i2c_hid 32768 0
i2c_piix4 28672 0
i8042 32768 1 acer_wmi
i915 2719744 0
intel_agp 24576 0
intel_gtt 24576 2 intel_agp,i915
ip_tables 32768 0
irqbypass 16384 1 kvm
joydev 28672 0
k10temp 16384 0
kvm 933888 1 kvm_amd
kvm_amd 114688 0
ledtrig_audio 16384 1 snd_hda_codec_generic
libarc4 16384 1 mac80211
libcrc32c 16384 1 btrfs
libps2 20480 1 atkbd
loop 40960 6
mac80211 1101824 1 ath10k_core
mac_hid 16384 0
mc 61440 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
mmc_core 192512 1 rtsx_pci_sdmmc
Module Size Used by
mousedev 24576 0
mxm_wmi 16384 1 nouveau
nouveau 2351104 0
ns 36864 1 qrtr
pinctrl_amd 32768 1
qrtr 20480 4
r8168 561152 0
radeon 1654784 0
raid6_pq 122880 1 btrfs
rapl 16384 0
rfcomm 90112 16
rfkill 28672 10 acer_wmi,bluetooth,cfg80211
rng_core 16384 2 ccp,tpm
rtsx_pci 106496 1 rtsx_pci_sdmmc
rtsx_pci_sdmmc 32768 0
serio 28672 4 serio_raw,atkbd,i8042
serio_raw 20480 0
snd 114688 26 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd
_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm
snd_compress 32768 1 snd_soc_core
snd_hda_codec 167936 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_codec_generic 98304 1 snd_hda_codec_realtek
snd_hda_codec_hdmi 73728 1
snd_hda_codec_realtek 155648 1
snd_hda_core 110592 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hda_intel 57344 6
snd_hrtimer 16384 1
snd_hwdep 16384 1 snd_hda_codec
snd_intel_dspcfg 28672 1 snd_hda_intel
snd_pcm 147456 8 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_compress,snd_soc_core,snd_hda_core,snd_
pcm_dmaengine
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_seq 90112 7 snd_seq_dummy
snd_seq_device 16384 1 snd_seq
snd_seq_dummy 16384 0
snd_soc_core 327680 1 soundwire_intel
snd_timer 49152 3 snd_seq,snd_hrtimer,snd_pcm
soundcore 16384 1 snd
soundwire_bus 90112 3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
soundwire_cadence 36864 1 soundwire_intel
soundwire_generic_allocation 16384 1 soundwire_intel
soundwire_intel 45056 1 snd_intel_dspcfg
sp5100_tco 20480 0
sparse_keymap 16384 1 acer_wmi
squashfs 69632 3
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
tpm 73728 3 tpm_tis,tpm_crb,tpm_tis_core
tpm_crb 20480 0
tpm_tis 16384 0
tpm_tis_core 28672 1 tpm_tis
ttm 114688 3 amdgpu,radeon,nouveau
uinput 20480 3
uvcvideo 114688 0
vboxdrv 532480 2 vboxnetadp,vboxnetflt
vboxnetadp 28672 0
vboxnetflt 32768 0
vfat 24576 1
video 57344 3 acer_wmi,i915,nouveau
videobuf2_common 65536 2 videobuf2_v4l2,uvcvideo
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 36864 1 uvcvideo
videobuf2_vmalloc 20480 1 uvcvideo
videodev 294912 3 videobuf2_v4l2,uvcvideo,videobuf2_common
wmi 36864 4 acer_wmi,wmi_bmof,mxm_wmi,nouveau
wmi_bmof 16384 0
xhci_pci 20480 0
xhci_pci_renesas 20480 1 xhci_pci
xor 24576 1 btrfs
x_tables 53248 1 ip_tables
zram 32768 1
