Hi everyone.
i recently shifted to Garuda. I'm in college and campus wifi has proxy (say 10.32.0.1 and port 8080). When I use wifi with password, everything works smoothly but using wifi with proxy is kind of a nightmare. e.g. I'm unable to update system, download/install any package with pacman or yay. I set the manual proxy in Network setting but still a lot of things are not working.
Please help me with this regard. How can I get everything run smoothly over wifi proxy.
When entering new topics, according to the relevant template, please always provide the output of
properly formatted, e.g. like this:
text
Sure thing.
Kernel: 5.18.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=cdb92a07-bc79-43a9-b857-e60ea34286a5 rw [email protected]
resume=UUID=c12bd5c5-0803-49b8-9d96-74c1d8168e88 loglevel=3
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FX505GD_FX505GD v: 1.0
Mobo: ASUSTeK model: FX505GD v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX505GD.308 date: 02/08/2021
ID-1: BAT0 charge: 34.4 Wh (100.0%) condition: 34.4/48.1 Wh (71.6%)
volts: 12.4 min: 11.7 model: Simplo SDI ICR18650 type: Li-ion
serial: <filter> status: full cycles: 41
Info: model: Intel Core i5-8300H socket: BGA1440 (U3E1) note: check
bits: 64 type: MT MCP arch: Coffee Lake gen: core 8 built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3967 high: 4002 min/max: 800/4000 base/boost: 2178/8300
ext-clock: 100 MHz cores: 1: 4000 2: 4001 3: 4002 4: 4000 5: 3806 6: 3971
7: 3965 8: 3991 bogomips: 36799
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: none bus-ID: 0000:00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 bus-ID: 0000:01:00.0 chip-ID: 10de:1c8d class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-11:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: Najing CEC Panda 0x002d built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.18.11-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
bus-ID: 0000:00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
driver: intel_nvme_remap v: N/A port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 38.82 GiB (3.3%)
model: PC SN520 SDAPNUW-256G-1002 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 20110000
temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 224d 12h cycles: 3,030
read-units: 61,441,960 [31.4 TB] written-units: 60,257,497 [30.8 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LX015-1U7172
family: FireCuda 2.5 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: SDM1 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 121d 3h cycles: 3027
read: 23.95 TiB written: 11.67 TiB Old-Age: g-sense error rate: 295
Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 38.82 GiB (16.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 7.62 GiB used: 1.13 GiB (14.8%)
System Temperatures: cpu: 50.0 C pch: 54.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 302 Uptime: 4h 3m wakeups: 13 Memory: 7.62 GiB
used: 3.28 GiB (43.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1259
lib: 320 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: kitty inxi: 3.3.19
e[1;34mGaruda (2.6.5-1):e[0m
e[1;34m System install date:e[0m 2022-07-14
e[1;34m Last full system update:e[0m 2022-07-19 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
As far as I can say, having no direct experience on this, I can only give you a few interesting Arch wiki articles about it:
https://wiki.archlinux.org/title/Proxy_server#Environment_variables
https://wiki.archlinux.org/title/Pacman#Pacman_does_not_honor_proxy_settings
https://wiki.archlinux.org/title/NetworkManager#Proxy_settings
You'll have to read a little bit and do some testing next time you can.
I'd go more towards setting the suggested environment variables and have sudo pass them to pacman, rather than trying the two suggested tools.
Of course, unless you'll get a more precise solution
Thank you very much. I read it and did some research and able to run pacman. I'm new in Linux and I struggle a bit. Will ask you again, if I'm stuck.
This is music to my ears...
Keep it up!
