Wifi option not visible
yesterday i dual booted garuda with windows, today when i turned on my laptop i am not able to connect to my wifi,
i get the follow error message
file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:10:1: plugin cannot be loaded for module "org.kde.plasma.networkmanagement": Cannot load library /usr/lib/qt/qml/org/kde/plasma/networkmanagement/libplasmanm_qmlplugins.so: (libKF5Wallet.so.5: cannot open shared object file: No such file or directory)
does it do it when you shutdown garuda and then restart garuda
I turned on my pc for the first time today and it happened i then restarted and the same issue was there
Did wifi work on first install?
Have you updated garuda with
garuda-update
as you are dual booting make sure fast boot is disabled in the bios and in windows>
Yes it worked yesterday whole day, i tried garuda-install but even that gave few signature errors with some email id listed so it wasnt complete
First thing is to rule out a potential problem with dual booting Windows: make sure that "fast boot" is disabled in the "BIOS", that is, the motherboard configuration screen accessed by pressing a key while booting (usually F2 but could be something else on yours).
Windows has this weird ability to "own" hardware across reboots, better disable it.
That said, I also have this problem and I don't dual boot, so it may well be something else.
I'm usually connected by ethernet to the modem/router, yesterday I had a network problem and while fumbling around I noticed that Wifi disappeared from network-manager.
A few reboots later it came back, and now isn't there anymore.
I've been quick to blame the ISP but maybe this time it wasn't their fault after all.
Note, I'm not on KDE but Sway, so I can't check that error message here.
@navneet:
This is currently provided by extra/kwallet 5.102.0-1
  • Can you post garuda-inxi
  • Can you post the result of pacman -Qi kwallet
That's very relevant to solving this. If the update didn't complete, let's get it fixed for everyone. What is the full text of the error?
@meanruse:
This is symptomatic of a longstanding powersave bug. The solution varies slightly based on the driver used, but the general fix is usually like this: wireless - No wifi adapter found! Dual boot windows 10 and Ubuntu 17.10 - Ask Ubuntu
The thing is, I don't dual boot.
There's no trace left of Windows on my laptop, not even a NTFS partition.
  Kernel: 6.1.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=592f1813-a12e-4fe0-a4bb-da4e2ce4dbea rw [email protected]
    quiet splash vt.global_cursor_default=0 loglevel=3 rd.udev.log_priority=3
    acpi_osi=Linux systemd.unified_cgroup_hierarchy=1
    resume=UUID=B5F8F072-9672-D546-B5BA-E3A0B73B9458
  Desktop: sway v: 1.8 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
  Type: Laptop System: TOSHIBA product: Satellite L500 v: PSLS3E-03V00TIT
  Mobo: TOSHIBA model: KSWAA v: 1.00 serial: <superuser required>
    BIOS: TOSHIBA v: 1.90 date: 12/17/2009
  ID-1: BAT1 charge: 42.0 Wh (100.0%) condition: 42.0/43.2 Wh (97.3%)
    volts: 12.2 min: 10.8 model: TOSHIBA PA3534U-1BRS type: Li-ion
  Info: model: Pentium T4400 bits: 64 type: MCP arch: Penryn level: v1
    built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
    stepping: 0xA (10) microcode: 0xA0B
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 1x1024 KiB
  Speed (MHz): avg: 1355 high: 1511 min/max: 1200/2200 scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1511 2: 1200
    bogomips: 8778
  Flags: ht lm nx pae sse sse2 sse3 ssse3
  Device-1: AMD RV710/M92 [Mobility Radeon HD 4530/4570/545v] vendor: Toshiba
    driver: radeon v: kernel alternate: amdgpu arch: TeraScale
    process: TSMC 55-65nm built: 2005-13 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 ports: active: HDMI-A-1,LVDS-1 empty: DP-1,VGA-1 bus-ID: 01:00.0
    chip-ID: 1002:9553 class-ID: 0300
  Device-2: Suyin USB 2.0 Camera type: USB driver: uvcvideo bus-ID: 1-6:2
    chip-ID: 064e:d104 class-ID: 0e02 serial: <filter>
  Display: wayland server: Xwayland v: 22.1.7 compositor: sway v: 1.8
    driver: gpu: radeon d-rect: 1366x1536 display-ID: 1
  Monitor-1: HDMI-A-1 pos: primary,top model: LG (GoldStar) TV
    serial: <filter> built: 2009 res: 1360x768 hz: 60 dpi: 49 gamma: 1.2
    scale: 1 size: 700x390mm (27.56x15.35") diag: 802mm (31.6") ratio: 16:9
    modes: max: 1360x768 min: 720x400
  Monitor-2: LVDS-1 pos: bottom model: LG Display LP156WH2-TLAA built: 2009
    res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 scale: 1
    max: 1366x768 min: 640x480
  API: OpenGL v: 3.3 Mesa 22.3.4 renderer: AMD RV710 (DRM 2.50.0 /
    6.1.9-zen1-1-zen LLVM 15.0.7) compat-v: 3.0 direct render: Yes
  Device-1: Intel 82801I HD Audio vendor: Toshiba driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e class-ID: 0403
  Device-2: AMD RV710/730 HDMI Audio [Radeon HD 4000 series] vendor: Toshiba
    bus-ID: 01:00.1 chip-ID: 1002:aa38 class-ID: 0403
  Sound API: ALSA v: k6.1.9-zen1-1-zen running: yes
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Toshiba
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000
    bus-ID: 0e:00.0 chip-ID: 10ec:8136 class-ID: 0200
  IF: enp14s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 298.09 GiB used: 60.16 GiB (20.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK3263GSXN
    size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: N/A serial: <filter> rev: 2M scheme: GPT
  ID-1: / raw-size: 42 GiB size: 42 GiB (100.00%) used: 26.64 GiB (63.4%)
    fs: btrfs dev: /dev/sda3 maj-min: 8:3
  ID-2: /home raw-size: 85.04 GiB size: 85.04 GiB (100.00%)
    used: 14.09 GiB (16.6%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
  ID-3: /var/log raw-size: 42 GiB size: 42 GiB (100.00%)
    used: 26.64 GiB (63.4%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
  ID-4: /var/tmp raw-size: 42 GiB size: 42 GiB (100.00%)
  ID-1: swap-1 type: zram size: 3.79 GiB used: 306.1 MiB (7.9%)
  ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda5 maj-min: 8:5
  System Temperatures: cpu: 43.0 C mobo: N/A
  Processes: 217 Uptime: 12h 50m wakeups: 2 Memory: 3.8 GiB
  used: 2.76 GiB (72.8%) Init: systemd v: 252 default: graphical
  pkgs: 2031 libs: 389 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash
  v: 5.1.16 running-in: alacritty inxi: 3.3.24
Garuda (2.6.14-1):
  System install date:     2021-12-03
  Last full system update: 2023-02-04
  Failed units:            nmb.service
And yet, Wifi card (that used to work) is now missing:
  Device-2: Realtek RTL8191SEvB Wireless LAN driver: rtl8192se v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 5000 bus-ID: 14:00.0
    chip-ID: 10ec:8172 class-ID: 0280
  IF: wlp20s0 state: down mac: <filter>
edit: it's there back again, after upgrade + reboot.
for the second cmd: error: package 'kwallet' was not found
for the first cmd:
root=UUID=c30620e0-87af-43f2-ab3f-82d276571f8d rw [email protected]
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
ID-1: BAT0 charge: 7.2 Wh (20.5%) condition: 35.2/48.1 Wh (73.1%)
volts: 10.3 min: 11.7 model: FX50442 type: Li-ion serial: N/A
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
stepping: 1 microcode: 0x8108102
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1850 high: 2773 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2773 2: 2770
3: 1231 4: 1400 5: 2768 6: 1400 7: 1231 8: 1231 bogomips: 33537
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-10)
arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s ports:
active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f91
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
ports: active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 56.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting,nouveau
alternate: fbdev,nv,vesa dri: radeonsi,nouveau gpu: amdgpu display-ID: :0
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0036 built: 2018
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.48
6.0.2-zen1-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
IF-ID-1: enp5s0f4u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:2 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
address: <filter>
Device-2: Huawei YAL-AL00 type: USB driver: rndis_host v: kernel
bus-ID: 3-2:4 chip-ID: 12d1:108a class-ID: 0a00 serial: <filter>
Local Storage: total: 476.94 GiB used: 6.48 GiB (1.4%)
model: MZVLQ512HALU-00000 size: 476.94 GiB block-size: physical: 512 B
rev: FXV7000Q temp: 25.9 C scheme: GPT
ID-1: / raw-size: 75 GiB size: 75 GiB (100.00%) used: 6.45 GiB (8.6%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 29.5 MiB
(30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 75 GiB size: 75 GiB (100.00%) used: 6.45 GiB (8.6%)
ID-4: /var/log raw-size: 75 GiB size: 75 GiB (100.00%) used: 6.45 GiB
(8.6%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-5: /var/tmp raw-size: 75 GiB size: 75 GiB (100.00%) used: 6.45 GiB
ID-1: swap-1 type: zram size: 13.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.5 C mobo: N/A
Fan Speeds (RPM): cpu: 2500
GPU: device: amdgpu temp: 55.0 C device: nouveau temp: N/A
Processes: 258 Uptime: 3h 34m wakeups: 3 Memory: 13.59 GiB used: 2.23 GiB
(16.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1137 libs: 301
Garuda (2.6.8-1):
System install date:     2023-02-05
Last full system update: 2023-02-05
Is partially upgraded:   Yes
sudo pacman -Rdd kwallet
i had tried this earlier to stop the kwallet on startup password prompt
thank you all
garuda-update remote fix
command worked for me, and now i have my wifi option back.
the main cause of the problem was this command
and now its resolved, though if you have any idea to disable startup prompt of kwallet please let me know
Update:
About the wifi, it disappeared again after another reboot. No dual boot involved.
I'll try garuda-update remote fix when I have a stable internet connection.
About my internet connectivity problem,
...and I was right.
Confirmed beyond reasonable doubt, I even found a newspaper article about it.
Yet when I called those scoundrels (telecom "Italia") they blamed it on me and tried to extort 30 euros to let me talk to a "technician".
