Wifi not scanning issue, fresh install dragonised version
I couldn’t scan the wifi available, wifi never had any problem when i was in windows.
when i click on the internet icon on the top right there is no available wifi network to show. i use internet by usb
note- during installation of the os it was not connected with internet, is it possible that it skip the networking driver dowloading process??
when i go to the garuda network assitance> linux driver> associated driver> it show no driver installed.
based on my search i have tried.
garuda-update
garuda-update remote fix
#turing on-off airplane mode and wifi from garuda rani
git clone https://aur.archlinux.org/rtl8821ce-dkms-git.git
cd rtl8821ce-dkms-git/
makepkg -si
Output of garuda-inix
Kernel: 6.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=99d01e39-6023-4648-b414-14a7c8e6f1a7 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Laptop System: Acer product: Aspire Lite AL15-41 v: N/A
Mobo: Acer model: Aspire Lite AL15-41 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> Firmware: UEFI
vendor: INSYDE v: 1.07.18RAC5 date: 08/08/2023
ID-1: BAT0 charge: 32.9 Wh (100%) condition: 32.9/36.2 Wh (90.9%)
volts: 12.47 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
charging: status: full cycles: N/A
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608108
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 414 min/max: 414/2100 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 414 2: 414 3: 414
4: 414 5: 414 6: 414 7: 414 8: 414 9: 414 10: 414 11: 414 12: 414
bogomips: 50303
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Lucienne vendor: CLEVO/KAPOK
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 05:00.0 chip-ID: 1002:164c class-ID: 0300
temp: 61.0 C
Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 5986:9102
class-ID: 0e02
Monitor-1: eDP-1 model: BOE Display 0x0812 built: 2018 res:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.7-arch1.1
renoir ACO DRM 3.64 6.17.9-zen1-1-zen) device-ID: 1002:164c
API: Vulkan v: 1.4.328 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.7-arch1.1
device-ID: 1002:164c surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.5 256 bits) driver: mesa llvmpipe v: 25.2.7-arch1.1 (LLVM
21.1.5) device-ID: 10005:0000 surfaces: N/A
Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: CLEVO/KAPOK driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 8 GT/s lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.17.9-zen1-1-zen status: kernel-api tools: N/A
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7902 802.11ax PCIe Wireless Network Adapter [Filogic
310] vendor: AzureWave driver: N/A pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:7902 class-ID: 0280
IF-ID-1: enp5s0f3u4 state: unknown speed: -1 duplex: unknown mac: <filter>
Device-1: Spreadtrum LAVA LZX415 driver: rndis_host v: kernel type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 1782:5d20
Device-2: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3580
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 476.94 GiB used: 6.82 GiB (1.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: LITE-ON
model: Phison ESO512GMLCT-E9C size: 476.94 GiB block-size: physical: 512 B
fw-rev: EJFM32.1 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 120.14 GiB size: 120.14 GiB (100.00%)
used: 6.78 GiB (5.6%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 31.6 MiB (12.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 120.14 GiB size: 120.14 GiB (100.00%)
ID-4: /var/log raw-size: 120.14 GiB size: 120.14 GiB (100.00%)
ID-5: /var/tmp raw-size: 120.14 GiB size: 120.14 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.96 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 65.0 C mobo: N/A gpu: amdgpu temp: 62.0 C
Memory: total: 16 GiB note: est. available: 14.96 GiB used: 4.53 GiB (30.3%)
Processes: 356 Power: uptime: 14m states: freeze,mem,disk suspend: s2idle
image: 5.97 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 258 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1236 libs: 317 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.2.1 running-in: konsole
inxi: 3.3.40
Garuda (2.11.1-1):
System install date:     2025-11-28
Last full system update: 2025-12-02
25/26 checks run in 1.89 seconds ⌛
Powered by garuda-health 🦅
It looks bad for you. As far as I know, there is still no Linux driver for this WiFi adapter.
Edit: If you absolutely need WiFi, then it would make the most sense to replace the adapter with an Intel WiFi card.
It looks like they are still working on it but, without vendor support, they can’t go far…
Anyway, here there is something to try in the meantime:
