I'm facing a problem while using wifi.
It keeps disconnecting in between.
And throw this error in notification saying. Wifi deactivated.
wireless interface wlan0
authentication application timed out
No problem while connecting. It just it gets disconnected while I have some important stuff to do.
I'm new to linux. Please bare with me.
Will share if any logs are required.
tbg
5 August 2021 03:30
2
Turn off wifi power saving.
If was disabled by default.
tbg
5 August 2021 03:34
4
I would then try disabling IPv6.
Please post:
inxi -Faz
System: Kernel: 5.13.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=cbc1d73a-a184-4c73-a229-b806a17fcb87
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP Pavilion Laptop 15-cs2xxx v: Type1ProductConfigId
Mobo: HP model: 84C1 v: 15.32 serial: <filter> UEFI: Insyde v: F.23 date: 12/25/2020
Battery: ID-1: BAT0 charge: 28.6 Wh (100.0%) condition: 28.6/28.6 Wh (100.0%) volts: 13.0 min: 11.6
model: HP Primary type: Li-ion serial: N/A status: Full
CPU: Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: B (11) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 3426 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 3426 2: 3728 3: 3693 4: 3779
5: 3736 6: 3648 7: 3688 8: 3644
Graphics: Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 02:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 0408:5300 class-ID: 0e02 serial: <filter>
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.7-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:c821
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-10:3
chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 6060
bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Drives: Local Storage: total: 1.14 TiB used: 14.29 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC501 HFM256GDJTNG-8310A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 80002C00 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-60Z10T0 size: 931.51 GiB
serial: <filter> rev: 1A04 scheme: MBR
Partition: ID-1: / raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 14.21 GiB (4.9%) fs: btrfs
dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 76.6 MiB (29.9%) fs: vfat
ID-3: /home raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 14.21 GiB (4.9%) fs: btrfs
ID-4: /var/log raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 14.21 GiB (4.9%) fs: btrfs
ID-5: /var/tmp raw-size: 292.97 GiB size: 292.97 GiB (100.00%) used: 14.21 GiB (4.9%) fs: btrfs
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 55.0 C mobo: N/A
Info: Processes: 301 Uptime: 1h 22m wakeups: 1 Memory: 7.66 GiB used: 4.8 GiB (62.6%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1250 lib: 300
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
tbg
5 August 2021 03:45
6
If possible try disabling PCI-Express power management in the BIOS or via a grub kernel boot parameter.
Test at least 4 alternate kernels such as, linux, linux-lts, linux-mainline, or linux-next-git for your Wifi issue.
Also disable MAC address randomization.
Will try this. Thank you for replying to that quickly.
Will get back if the problem persists.
Can you please tell the process for disabling MAC address randomization.
tbg
5 August 2021 03:54
9
Search is your friend try the forums, it helps.
Garuda Network Assistant
Yup just got that answer in another post.
tbg
5 August 2021 03:58
11
Do the disconnects occur randomly or at regular intervals?
How frequently?
Just disabled the MAC address randomization, now a new pop up is coming stating network can't be found.
Randomly. Mostly while doing something important. Got disconnected 3 times while talking to you.
tbg
5 August 2021 04:17
14
https://bbs.archlinux.org/viewtopic.php?id=265820
You could also try locking your wifi to a single bssid in network manager.
removed all connections and using only the 2.4GHz band. But the issue still persists.
filo
5 August 2021 05:13
16
Maybe you could give a try to the rtl8821-dkms-git driver in the AUR.
I don't know if this will require to blacklist your current driver or it will be done automatically.
Although, before fumbling with drivers, I'd give priority to the other kernels.
Recently a user, with your card although on a different HP model was experiencing freezes with wifi and solved with maineline kernel. Of course that's different, Just to say that testing kernels is important.
tbg
5 August 2021 06:23
17
I think rtw88-dkms-git would be the preferred driver if you were to install an out of kernel driver. You would be best to test other kernels first before you go that route.
tbg
5 August 2021 06:28
18
I missed this post. Be sure to reboot both your computer and router afterwards.
Tried installing rtw88-dkms-git with Linux-lts & linux-mainline. Still facing the same issue.
Are you dual booting
If answer is yes then that's the cause
