Tried disabling both Ethernet and Wifi in device manager, after a cold boot i still have the same issue.
Unfortunately i don’t have an Android and have only tried tethering on iPhone, ik iPhone does have a couple issues so that may be why.
╭─luke@TrafalgarDLaw in ~
╰─λ inxi -nxz
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: N/A port: N/A
bus-ID: 00:1f.6
Device-2: TP-Link 802.11ac WLAN Adapter driver: N/A type: USB
bus-ID: 1-2:2
╰─λ sudo dmesg | grep -Ei 'rtl|wl|eth|firm'
[ 3.305123] usb 1-2: Prduct: 802.11ac WLAN Adapter
[ 13.115944] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adls_dmc_ver2_01.bin (v2.1)
[ 13.155015] i915 0000:00:02.0: [drm] GT0: GuC firmware i915/tgl_guc_70.bin version 70.20.0
[ 13.155018] i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
[ 13.174316] i915 display info: has_cdclk_crawl: no
[ 16.368031] [drm] Loading DMUB firmware via PSP: version=0x02020020
[ 16.368308] [drm] Found VCN firmware Version ENC: 1.30 DEC: 3 VEP: 0 Revision: 4
[ 16.368311] amdgpu 0000:03:00.0: amdgpu: Will use PSP to load VCN firmware
╰─λ hwinfo --netcard --bluetooth | grep -Ei "(speed|hotplug|model|status|cmd|file|detected|driver:)" | grep -v "Config S"
Model: "Intel Ethernet Connection (17) I219-V"
Driver Status: e1000e is active
Driver Activation Cmd: "modprobe e1000e"
These are the outputs on the installed system
I have tried unplugging LAN and Wi-Fi before startup unfortunately that didn’t work either
