Hi there! As I am new to linux and choose Garuda as my first one.
So I have very less knowledge about linux and how it works.
My problem is that I want my wifi connection ( Mobile Hotspot ) to be treated as privet connection because I want to play Minecraft ( Tlauncher ) multiplayer through LAN and it detects other severs on same network but can't connect to it and my LAN world is not visible to other pc also. I tried to find solution to this and find that if your wifi connection is not treated as privet this problem can occurs. SO if you have a solution to this plz let me know.
System: Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=3d1a25b0-a573-4133-a6d1-64b8e17610e7
systemd.unified_cgroup_hierarchy=1 resume=UUID=3ab3ad0c-3c59-4ec9-90fa-361cceef2dbb loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: Dell product: Vostro 3470 v: N/A serial: <filter> Chassis: type: 3
Mobo: Dell model: 03NJH0 v: A00 serial: <filter> UEFI: Dell v: 2.15.0 date: 02/21/2020
CPU: Info: Quad Core model: Intel Core i3-8100 bits: 64 type: MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: B (11) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 3600 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 3600 2: 3600 3: 3600 4: 3600
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e91 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Monitor-1: DP2 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Dell Vostro 3470 driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell Vostro 3470
driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Dell Vostro 3470
driver: ath9k v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 0cf3:e005
Drives: Local Storage: total: 931.51 GiB used: 8.19 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-75WN4A0 size: 931.51 GiB
serial: <filter> rev: 1A02 scheme: MBR
Partition: ID-1: / raw-size: 300 GiB size: 300 GiB (100.00%) used: 8.18 GiB (2.7%) fs: btrfs
dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 300 GiB size: 300 GiB (100.00%) used: 8.18 GiB (2.7%) fs: btrfs
ID-4: /var/log raw-size: 300 GiB size: 300 GiB (100.00%) used: 8.18 GiB (2.7%) fs: btrfs
ID-5: /var/tmp raw-size: 300 GiB size: 300 GiB (100.00%) used: 8.18 GiB (2.7%) fs: btrfs
ID-1: swap-1 type: zram size: 3.66 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda1
maj-min: 8:1
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 994
Info: Processes: 201 Uptime: 6m wakeups: 0 Memory: 3.66 GiB used: 1.86 GiB (50.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1123 lib: 290
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
