LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_US.UTF-8",
LC_NAME = "en_US.UTF-8",
LC_MONETARY = "en_US.UTF-8",
LC_PAPER = "en_US.UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8",
LC_TELEPHONE = "en_US.UTF-8",
LC_MEASUREMENT = "en_US.UTF-8",
LC_TIME = "en_IN.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.2.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=aaea0b1c-9815-4ca5-8bf1-22d12decc96f rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
Mobo: HP model: 81F0 v: 63.21 serial: <superuser required> UEFI: Insyde
v: F.44 date: 08/07/2018
ID-1: BAT1 charge: 7.6 Wh (100.0%) condition: 7.6/32.6 Wh (23.2%)
volts: 16.5 min: 14.8 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1897 high: 1900 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1900 2: 1896 3: 1896
4: 1896 bogomips: 15964
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 0d:00.0 chip-ID: 1002:6660 class-ID: 0380
temp: 41.0 C
Device-3: Chicony HP TrueVision HD type: USB driver: uvcvideo
bus-ID: 2-5:4 chip-ID: 04f2:b56c class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: iris,radeonsi gpu: i915 display-ID: :0
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x70ec built: 2015 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k6.2.12-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 5000
bus-ID: 07:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 13:00.0 chip-ID: 14e4:4365 class-ID: 0280
IF: wlp19s0 state: up mac: <filter>
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 2-4:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 931.51 GiB used: 121 GiB (13.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010A9E680
type: HDD rpm: 5400 serial: <filter> rev: A7G0 scheme: MBR
ID-1: / raw-size: 97.97 GiB size: 97.97 GiB (100.00%)
used: 19.68 GiB (20.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 549 MiB size: 547.9 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 97.97 GiB size: 97.97 GiB (100.00%)
ID-4: /var/log raw-size: 97.97 GiB size: 97.97 GiB (100.00%)
ID-5: /var/tmp raw-size: 97.97 GiB size: 97.97 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C pch: 45.0 C mobo: N/A gpu: radeon
temp: 41.0 C
Processes: 204 Uptime: 1h 40m wakeups: 3 Memory: 7.67 GiB
used: 3.04 GiB (39.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1822
libs: 543 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date: 2023-04-01
Last full system update: 2023-04-25
My problem is that my wifi after connecting for sometime shows limited connectivity message & browser & internet related things go down the wifi icon also changes from white to orange color any solution ?? (no problem with wifi working fine in other devices)
