hello
i tried other ditros that were debain and ubuntu based before and there was no issue
after installing garuda xfce when i connect my earphone to motherboard it does not work and i cant find it in sound device list.
however my monitor has a speaker and also 3.5 jack output using that i can use my earphone but motherboard does not work.
realtek ALC887
kernel 5.10.63-1-lts
i already updated the system
Please post your inxi -Faz
Host: reznov Kernel: 5.10.63-1-lts x86_64 bits: 64 Desktop: Xfce 4.16.0
Distro: Garuda Linux
Type: Desktop Mobo: ASUSTeK model: TUF Z370-PLUS GAMING II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2403
date: 08/07/2020
Info: Quad Core model: Intel Core i3-9100F bits: 64 type: MCP cache:
L2: 6 MiB
Speed: 4151 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 4151 2: 4193
3: 4122 4: 4107
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] driver: amdgpu
v: kernel
Display: x11 server: X.Org 1.20.13 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon resolution: 1920x1080~60Hz
OpenGL:
renderer: Radeon RX 5500 XT (NAVI14 DRM 3.40.0 5.10.63-1-lts LLVM 12.0.1)
v: 4.6 Mesa 21.2.1
**Audio:**
** Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel **
** Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel **
** Sound Server-1: ALSA v: k5.10.63-1-lts running: yes **
** Sound Server-2: PulseAudio v: 15.0 running: yes **
** Sound Server-3: PipeWire v: 0.3.35 running: yes**
Device-1: Intel Ethernet I219-V driver: e1000e
IF: eno1 state: up speed: 100 Mbps duplex: full mac: 04:92:26:d3:ca:d2
IF-ID-1: anbox0 state: down mac: de:86:29:99:01:5f
Local Storage: total: 3.9 TiB used: 36.3 GiB (0.9%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX6000LNP size: 238.47 GiB
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-08WN4A0
ID-3: /dev/sdb vendor: Western Digital model: WD10EZRX-00A8LB0
ID-4: /dev/sdc vendor: Western Digital model: WD20ERZ-00Z5HB0
ID-5: /dev/sdd type: USB model: USB Flash Disk size: 29.76 GiB
ID-1: / size: 238.21 GiB used: 16.82 GiB (7.1%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 256 MiB used: 562 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 238.21 GiB used: 16.82 GiB (7.1%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 238.21 GiB used: 16.82 GiB (7.1%) fs: btrfs
dev: /dev/nvme0n1p2
ID-5: /var/tmp size: 238.21 GiB used: 16.82 GiB (7.1%) fs: btrfs
dev: /dev/nvme0n1p2
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) dev: /dev/zram0
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 37.0 C
Processes: 252 Uptime: 24m Memory: 15.57 GiB used: 2.51 GiB (16.1%)
Shell: Bash inxi: 3.3.06
If you include terminal outputs in your post please use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
I’m no expert on this stuff, but is this normal/OK?
I’m asking this because I always see only one of the two enabled (I think by default it should be PipeWire now).
Msybe you could try disabling PulseAudio.
Audio: Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 0b:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.14.2-4-cacule running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Work here, but it's not my world this audio stuff
Maybe he must change something in volume control, like me, sometimes.
