Hello.
This is my first time posting so be nice especially since I'm posting in the newbie corner.
I want to run zsh but it is saying that my shell is fish and I can't seem to change it.
inxi -Faz
Kernel: 5.16.0-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5ea32362-776b-4a64-a2e7-1e1492b1137b rw rootflags=subvol=@
resume=UUID=99213909-149f-4663-8cb0-b7431f100328 loglevel=3
Desktop: sway 1.6.1 vt: 1 dm: N/A Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 13 9350 v: N/A
serial: <superuser required> Chassis: type: 9
Mobo: Dell model: 0PWNCR v: A01 serial: <superuser required> UEFI: Dell
v: 1.11.1 date: 08/01/2019
ID-1: BAT0 charge: 32.3 Wh (94.2%) condition: 34.3/56.0 Wh (61.2%)
volts: 8.7 min: 7.6 model: LGC-LGC7.3 DELL 5K9CP5A type: Li-ion
serial: <filter> status: Charging
Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 491 high: 500 min/max: 400/3100 scaling:
driver: intel_pstate governor: powersave cores: 1: 466 2: 500 3: 500
4: 500 bogomips: 20799
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0c45:670c class-ID: 0e02
Display: wayland server: N/A compositor: sway v: 1.6.1 driver:
loaded: i915 note: n/a (using device driver) display-ID: 1
resolution: <missing: xdpyinfo>
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 3a:00.0
chip-ID: 8086:095a class-ID: 0280
IF: wlp58s0 state: up mac: <filter>
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus-ID: 1-3:3 chip-ID: 8087:0a2a class-ID: e001
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 465.76 GiB used: 18.54 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung
model: SSD 860 EVO M.2 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2B6Q
ID-1: / raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
used: 18.54 GiB (4.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-4: /var/log raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.63 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 49.0 C pch: 45.5 C mobo: 41.0 C
sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 242 Uptime: 53m wakeups: 1 Memory: 7.63 GiB
used: 3.25 GiB (42.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1273 lib: 316 Shell: fish
v: 3.3.1 default: Zsh v: 5.8 running-in: alacritty inxi: 3.3.11~~~
Steps I have taken to solve my problem:
- I have tried chsh
- Also going through the gardua assistant/welcome setup.
I am also trying to take make a change to zshrc and I get the standard fish shell error information when I try to source zshrc.
If I launch my terminal and then I try source .zshrc
. I get this error which to me looks like a fish error.
[🔴] × source ~/.zshrc
~/.zshrc (line 185): Missing end to balance this if statement
if [[ -n "${key[Alt-Right]}" ]]; then
from sourcing file ~/.zshrc
source: Error while reading file “/home/userprofile/.zshrc”
Thanks.
