Why does garuda constantly flicker on games?
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6f7ae3fc-7e25-4c8c-8419-89e325646b4c rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop System: Gigabyte product: B550 AORUS ELITE v: N/A
Mobo: Gigabyte model: B550 AORUS ELITE v: x.x serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends v: F10 date: 09/18/2020
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3952 high: 4194 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4194 2: 4115
3: 3765 4: 3452 5: 4182 6: 4191 7: 3600 8: 4194 9: 3600 10: 4029 11: 4192
12: 4185 13: 3725 14: 4193 15: 4192 16: 3430 bogomips: 114986
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: eVga.com.
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-3
empty: DP-1, DP-2, HDMI-A-1, Unknown-2 bus-ID: 0a:00.0 chip-ID: 10de:1e84
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: DP-3 res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070
SUPER/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2070 SUPER driver: nvidia v: 550.54.14 device-ID: 10de:1e84
Device-1: NVIDIA TU104 HD Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1
Device-3: HP HyperX SoloCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3
chip-ID: 03f0:078b class-ID: 0300
Device-4: Razer USA BlackShark V2 Pro
lanes: 1 mode: 1.1 bus-ID: 1-9:7 chip-ID: 1532:0528 class-ID: 0300
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0
Local Storage: total: 1.36 TiB used: 152.36 GiB (10.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 52.9 C
scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 53.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 152.34 GiB (32.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 4.08 GiB (13.0%)
System Temperatures: cpu: 64.1 C mobo: 46.0 C
Memory: total: 32 GiB available: 31.28 GiB used: 7.06 GiB (22.6%)
Processes: 544 Power: uptime: 6h 46m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,
Packages: 1980 pm: dpkg pkgs: 3 tools: apt,apt-get pm: pacman pkgs: 1977
libs: 544 tools: octopi,paru Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-03-10
Last full system update: 2024-03-13 ↻
Does this happen also if you log into an x11 session?
It is well known that Wayland does not get along with Nvidia and even more so with KDE6.
Nothing is in Garuda’s hands and responsibility.
A reboot is pending, just in case…
I’ve rebooted many times and it hasn’t ever updated
Did you try?
The means, KDE needs a restart.
The template help
Rebooting will refresh the system after the update.
Restarting the system after update works. Shutting down didn’t.
Then you go to a terminal
systemctl shutdown -h now
or also
systemctl reboot
KDE sometimes hangs at certain points after updates.
Especially at the moment. Plasma 5 to 6
