Hi,
I am currently about to change my wifi/bluetooth card, since mine which is the Realtek RTL8822CE 802.11ac
is quite annoying in some aspects like that it seems to not support p2p which is needed for miracast. Also there where quite some unique problems with that card. And before I purchase a card, which has similar problems, I want to ask here, which cards which have both wifi and bluetooth, are recommendable. A link to Amazon or smth similar would be nice.
Kernel: 5.17.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f9eaa1e8-1165-45cd-9cd0-cd66869e39f5 rw rootflags=subvol=@
Type: Laptop System: HUAWEI product: KLVL-WXX9 v: M1560
Mobo: HUAWEI model: KLVL-WXX9-PCB v: M1560 serial: <superuser required>
UEFI: HUAWEI v: 1.06 date: 09/14/2020
ID-1: BAT0 charge: 10.6 Wh (19.2%) condition: 55.1/54.9 Wh (100.3%)
volts: 7.3 min: 7.6 model: DYNAPACK HB4593R1ECW-22T0 type: Li-ion
serial: <filter> status: discharging cycles: 87
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1391 high: 1397 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1396 2: 1397
3: 1361 4: 1349 5: 1397 6: 1394 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397
12: 1397 13: 1397 14: 1397 15: 1397 16: 1397 bogomips: 92628
Device-1: AMD Renoir driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 13d3:5451 class-ID: 0e02 serial: <filter>
Screen-1: 0 s-res: 2160x1440 s-dpi: 96 s-size: 571x381mm (22.48x15.00")
s-diag: 686mm (27.03")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0893 built: 2019
res: 2160x1440 hz: 60 dpi: 185 gamma: 1.2 size: 296x197mm (11.65x7.76")
diag: 356mm (14") ratio: 3:2 modes: max: 2160x1440 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.7-zen1-2-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.17.7-zen1-2-zen running: yes
vendor: & Tele RSH driver: rtw_8822ce v: kernel modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
bus-ID: 3-3:2 chip-ID: 1358:c123 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 97.11 GiB (20.4%)
model: PC SN530 SDBPNPZ-512G-1027 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21117000 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 313 GiB size: 313 GiB (100.00%) used: 97.09 GiB (31.0%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 25.5 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 313 GiB size: 313 GiB (100.00%)
used: 97.09 GiB (31.0%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 313 GiB size: 313 GiB (100.00%)
ID-5: /var/tmp raw-size: 313 GiB size: 313 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.07 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 36.0 C
Processes: 375 Uptime: 1h 11m wakeups: 2 Memory: 15.07 GiB
used: 4.43 GiB (29.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 2009 pacman: 1999 lib: 554 flatpak: 6
snap: 4 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
Garuda (2.6.3-2):
System install date: 2022-04-23
Last full system update: 2022-05-21 ↻
