I have found this alias on my fish.conf
alias rmpkg="sudo pacman -Rdd"
Are there benefits of using this alias instead of sudo pacman -Rns
https://wiki.archlinux.org/title/pacman
To remove a package, which is required by another package, without removing the dependent package:
Warning: The following operation can break a system and should be avoided. See System maintenance#Avoid certain pacman commands.
Hi, with alias you can use any name you wish and can remember. Myself I just use the real command.
I understand how aliases work, I wonder about which one to always use and never break stuff
They are both the same. You create it to use the command.
I think I should use sudo pacman/yay -Rns for "big" ( packages ) and sudo pacman/yay -Rdd for small ones.
Correct me if I'm wrong which I probably am
If you open up a 'Terminal' and type 'man pacman' you will see what choices do what.
For sure but I also think that you should modify the alias to -Rns cause that should be default and used most of the time according to what I've read
-Rns
is what I use. Hearing-Rdd
for the first time and personally I never used it
For me -Rns
makes more sense, since, after uninstalling a package, it's orphans are useless.
Dito, best way to get rid of all the leftovers automatically.
I occasionally use -Rdd
for special purposes such as getting rid of a few packages which are dependency of another package (absolutely not recommended btw, depends are there for a reason) but not needed for my own setup.
And sudo pacman -Rns $(pacman -Qtdq)
will remove orphans.
And please see Pacman Rosetta for more comprehensive, human-readable information.
