Which iso to choose for a fresh installation?
So, I have to do a fresh installation of Garuda on my new laptop…
I am going to install the dragonzied version.
I am wondering which iso should i have to install the new beta testers iso or the official iso from website. As Garuda is rolling release so it needs to be same na?
Any information regarding this is highly appreciable. :nerd_face:
Do you want to be a beta tester? That means reporting any errors or failures, and how you solved them. Are you that capable? :slight_smile:
I am currently using the beta version of dragonzied edition released on 28th of September and it is working seamlessly well. No error recorded so far just sometimes whenever something add or delete in desktop there is a little lag and that’s it nothing else.
This isn’t really a beta version, it just hasn’t been tested yet to see if it runs on real hardware, or if the live ISO boots at all, with and without Nvidia GPU.
We also only get further if not everyone tests KDE :slight_smile:
Desktop
Cinnamon
dr460nized
dr460nized-gaming
gnome
hyprland
i3wm
kde-lite
lxqt-kwin
mate
qtile
sway
wayfire
xfce
