Garuda Wayfire today's download. Connman finds the wifi, but I can't find the place to write the wifi password to get the internet on.
Connman should ask if it needs one. Can you post the output of connman from when you try to connect?
Also please post the output of inxi -Fxxxa
with ~~~ above and below it.
As it is wifi, I have to give the password, so there should be a place to fill that. Tried to get a screenshot, which is supposed to be saved in Pictures, but Files don't open at all. So, something must be wrong with this release. Anyway, I'll try again and give what you asked.
Tried again. Neither Files, nor Text Editor opens. I am writing this from another distro.
Which GPU you use?
We need information to help. Please try to help us help you - what chip/driver is in use for the WiFi adapter?
Are you using ConnMan on the command line or using it with a GUI front-end?
Can you open a console ctl-alt-F3
? If so, can you li
the directories you would store pictures and text in? What does it say about space taken?
I'll download afresh later in the evening and try it again. I cannot try now.
Like I mentioned before,
- I used the GUI frontend. Once, a wifi network is chosen (clicked on), it should ask for the password for the internet. It doesn't. I have only wifi. Wifi doesn't get enabled at start, have to do that manually.
- Neither the Files, nor the Text editor opened, so there's no place to find the stored screenshots etc.
Info: Quad Core model: Intel Core i5-1035G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6
cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 19048
Speed: 1100 MHz min/max: 400/3600 MHz Core speeds (MHz): 1: 1100 2: 1030
3: 1100 4: 1100 5: 1099 6: 1100 7: 1100 8: 1101
Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel modules: wl port: 3040
bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlan0 state: up mac: 10:63:c8:fd:fe:8b
This is from Arch
This is a known bug, install connman-git
as a workaround.
