Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
misobasedir=garuda misolabel=GARUDA_DR460NIZEDGAMING_WHITETAI quiet
systemd.show_status=1 driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
Type: Laptop System: LENOVO product: 80XR v: Lenovo ideapad 320-15IAP
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 320-15IAP
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: 5RCN30WW date: 10/23/2017
ID-1: BAT0 charge: 20.1 Wh (100.0%) condition: 20.1/30.0 Wh (67.1%)
volts: 8.4 min: 7.5 model: SMP L16M2PB1 type: Li-poly serial: <filter>
status: Full
Info: model: Intel Pentium N4200 bits: 64 type: MCP arch: Goldmont
family: 6 model-id: 0x5C (92) stepping: 9 microcode: 0x20
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 2287 high: 2288 min/max: 800/2500 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2288 2: 2288 3: 2288
4: 2284 bogomips: 8755
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Integrated
Graphics
vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5a84
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 / M440/M445 /
530/535 / 620/625 Mobile]
vendor: Lenovo driver: amdgpu v: kernel bus-ID: 01:00.0
chip-ID: 1002:6900 class-ID: 0380
Device-3: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 5986:1127 class-ID: 0e02 serial: <filter>
loaded: amdgpu,ati,intel unloaded: modesetting alternate: fbdev,vesa
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 505 (APL 3) v: 4.6 Mesa 21.3.3
direct render: Yes
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:5a98 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8136
Device-2: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtl8821ae v: kernel port: 1000 bus-ID: 03:00.0
chip-ID: 10ec:8821 class-ID: 0280
Device-1: Realtek RTL8821A Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-8:5 chip-ID: 0bda:0821 class-ID: e001 serial: <filter>
Local Storage: total: 960.81 GiB used: 13.9 GiB (1.4%)
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LCM2
ID-2: /dev/sdb maj-min: 8:16 type: USB model: N/A size: 29.3 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 2.00 scheme: MBR
ID-1: swap-1 type: zram size: 3.66 GiB used: 2.98 GiB (81.3%)
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 245 Uptime: 2h 20m wakeups: 3 Memory: 3.66 GiB
used: 3.07 GiB (83.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1731 lib: 510 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
when i install garuda i get this error massege
the bootloader could not be installed. the installation command <pre>grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Garuda --force</pre>
reterned arror code 1
sorry for category i dont know how to chenge it now
